- 1 Sep 2013
Settings:
ring at 35 ratio, VCCIN voltage:2.100.
cpu core voltage:1.250
ring voltage: 1.125
4.2ghz: 20 Intel burn tests at High setting, max temp 85c
4.3ghz: 20 IBT tests at high aswel, max temp: 86-87c
4.3ghz: prime 95 1 hour torture test, max temp: 75c
Obvs underload.
Are these overclocks safe for 24/7 use? I only play games and edit photos as well as music and web surf on this machine.
What's next? Use the pc as normal and see if it BSOD's or would the IBT 20 runs at high show its stable?
ring voltage: 1.125
Obvs underload.
