Will regular cotton from superdrug do? Unfortunately I can't find anything like this in the UK: http://www.seducejuice.com/cotton_wick.html
My vaping is becoming tasteless but still producing a big cloud. Does this mean the cartomiser is running out of life?
How frequent is it expected that one should be changing the spring, wick, and cartomiser?
Cheers!![]()
It generally means the wick is knackered or the coil is gunked up. You can try rinsing it out and letting it dry (important) and give it another go, but the easier solution is to bin it and replace.
Other possibilities: You have been vaping the same flavour for ages and your tongue has decided it doesn't want to taste it anymore (vapers tongue!), in which case you need to use a different flavour for a while. Or you are running your coil a bit too hot and losing some flavour in the process. Generally only an issue with VV/VW mods running on the higher end of the scale, but some flavours do like cooler coils.
After reading a post here, may go for a pro tank 2 (will this fit on my ego-T starter kit battery, is it a 'generic' screw on size for the majority of components?), and some chocolate juice![]()
Cheers dude,
I'll clean out the coil, and order a new coil regardless.
