*** Official OcUK Minecraft Server - Discussion and Rules ***
Just done all the required for whitelisting to vanilla.
Not seeing my post on your forum though so I guess you have post approval or new thread approval on? No rush, I see you are doing some moving around don't want to disturb so just when convinient.
Cheers =D
Cheers =D
Hi there. Looks to me that the post got eaten unfortunately :/ if you could post in the whitelist forum again I will check up on it all tonight.
I've possibly fixed the issue Yrth was having with the mod server. Can someone test it and let me know their results?
You may need to delete the server entry and then re-add it before you can join.
Hi, tried the linktart.co.uk:15565
says failed to connect to server, connection refused: connect.
also tried deleting that and adding it again.
The white mojang screen seems to take a while to finish, but sometimes it just does.
From the info corner
Minecraft 1.4.7
MCP v7.26a
FML v4.7.35.556
Minecraft Forge 6.6.2.534
Feed the beast mod pack
97 mods loaded, 96 mods active (mcore disabled)
Just in case I missed anything about updating.
Tefal, here's a map of the ocean area surrounding our current home base, the map is 2k x 2k in size. You can find a copy of the map in our ender chest. I've labelled a couple of features but there is more villages, witches huts etc. Have a look at the locations and let me know what you think. The interior of the underwater base can be given a futuristic theme using quartz and the various shades of hardened clay or it can be an ancient abandoned look.
http://i.imgur.com/IRzTTrJ.png
Expanded the map as the ocean continues but the original suggested location still looks good, just need to work out the dimensions now.
Hi, thanks for that I can confirm it is working :)
However it appears to have been rolled back a week or so ?
I'm down about a third of a chest of diamonds and missing a few new spells and random things aquired whilst adventuring, some new machines and some glowstone.
It's the spells I'll miss most because I've no idea where I found them.
It's not a problem though, I can fix most of it.
I copied the current files at the time I took the server down so there shouldn't have been any rollback. Perhaps yrth can shed some light on this?
Few things to be aware of for the current ftb that we using on server
Using the Force Wrench on ThermalExpansion machines/blocks results in a server wide crash on multi-player servers.
Unable to create Force Stick with current recipe. (Workaround admin create a vendor at spawn for them the item is needed for a few things).
Hi guys, registered a user on the forums for whitelisting, could you have a looksie as I haven't seen an email back and not sure If I'm doing the right thing.
Take it easy, complete MC noob here :)
