Spec me a permanent fine nib white marker pen
17 Aug 2009
Finchley, London
Calling all ye pen pushers.. I mean, experts on quality pens. I want to white paint over half a dozen pinhead and nailhead size brown spot stains on the front of a white v neck t-shirt type top I have. I've washed it twice with Vanish and also some of that bleaching agent oxi cleaner stuff which has bleaching agent but these stains won't come out. I'd thought of fabric markers but now I'm thinking a permanent marker pen would do the job. The best one I've found so far is a Pilot White marker, extra fine point approx 2mm nib. It's only £3.20
Reviews are generally good, slightly mixed, but one person said the tip worked it's way loose and fell out and another said the paint was a bit thin and needed a few coats. So can anyone recommend a trusted brand or particular pen they might have used, with fine tip, permanent ink, in white, where the tip doesn't fall out and the paint is not too watery? :)
lol thats a very specific spec me ... just get that one, use it and get on with life surely ?
I want one too! I have a mouldy shirt from when I went to download last year, left it in a white bag for a week before doing anything with it.
(Yes, that's gross, but I don't care)
Regardless of where you shop, spending 30 on a t-shirt is daft and you should feel bad.
Not all of us are stupid enough to spend £30 on a tshirt either. What a ridiculous price
It's exactly the same as someone picking an Audi A3 over a Ford Focus.
Is he wrong for spending more money too?
I'm not going to get into the difference between cheap and expensive brands, its like trying to argue with a deaf person about the best music.
The point i was making originally, was the t-shirt might not be cheap, so could be worth fixing.
