It's not just me but other posters in this thread that have taken you to task over this because you're making out you have amazing super senses on the road.
As far as I know none of us have actually been in accidents but we know on occasions that no amount of being careful can cater for the idiot that suddenly left hooks.
You on the other hand can or at the very least if they left hook and you hit them then it would be your fault (or partly at least).
Stop being silly and just admit that yes, no matter how much being careful you can be there can be a situation where you get left hooked and it is 100% not your fault.
And plenty of others have seen and understood exactly the points I have been making and agreed with them.
I did not say at any point that you can avoid every accident...that is something you assumed...I do not know why, because I have said you cannot avoid everything often enough...I even said that if someone turns into you then it is their fault and you cant do much about it...I said that doesn't appear to be the case with the incdent in the OP, which you now agree with me on it seems...
Your response however illustrates that you do not fully understand my perspective and therefore are making assumptions that are not correct about it. Perhaps you can simply accept that I did not say or mean that 100% of accidents are avoidable, or that in 100% of case you are at least partially responsible, because regardless of how you are reading it, that is not what I meant or said.
I'm a little confused tbh, there seems to be some misunderstanding going on.
