I currently have a couple of 3TB Red Drives in mirrored mode in my PC. I use these to store all of my Movies, Photos, Music etc., I have about 800GB left so I know I will have to upgrade at some point in the future and want to make it one that will last me for years.
I have 2TB Green drive in my HTPC which provides some level of backup to my main PC.
I have done a bit of research and I think I will be going down the Wireless 802.11ac route when the prices come down which should provide decent transfer speeds around the house so I can use my media comfortably on all devices.
Basically I want to know what my best option would be to house everything in with the ability to upgrade as I go.
Option 1
Synology DS1513+ with 3-5 WD Red 4TB drives.
If I started off with 3 drives what would be the best RAID configuration to go for? I was thinking 5 but have heard mixed reviews.
Also could I add and 4th and 5th drive into the unit at any time? Would this delete any of my data? Or would it just rebuild itself and spread the existing data across the extra drive(s)?
I understand the concept of RAID and that it doesn’t provide a backup but does account for redundancy from a failed drive.
What I don’t understand is quite how I can back up 8TB to 16TB of data without spending a fortune by building the NAS twice!
Would Cloud storage be the answer here?
Option 2:
I have also been considering building my own NAS unit.
Is it possible to have a NAS style setup running inside a PC and being able to use the PC as a media centre/steam box at the same time?
My idea would be to have
3-5 x WD Red 4TB
1 x WD Black 3TB-4TB
1 x SSD 128GB-256GB
The 3-5 red drives would be the NAS side of the computer whilst the rest would be used to run windows and my steam games so it can all be plugged into the TV in the lounge.
Same question as before am I able to add drives to the RAID without losing data?
Also I wanted some advice on case choice and have been looking at Lian Li and Silverstone but obviously need room for 6 x 3.5" drives and an SSD.
The unit needs to fit to the below dimensions so it can be put in my TV unit.
W = 480mm
H = 175mm
D = 400mm
How easy is NAS to setup? I have read reviews on FreeNAS and that seems to be being pretty good.
Again I run into the issue of backups and would like to know what some of you guys do with large amount of data?
Cheers,
Option 1
Option 2:
3-5 x WD Red 4TB
1 x SSD 128GB-256GB
W = 480mm
H = 175mm
D = 400mm
Cheers,
