- 6 Feb 2010
Wait...so you are telling us that a Q6600 at 3.40GHz with a 7850 giving less than half the minimum frame rate comparing to a i5 3470 with a 7770 on the same graphic setting is NOT a huge bottleneck?Not huge but noticeable on bf3 in the 48 and up player range. Below that it's fine. Also in blacklist when using night vision, there are dips down to 25 fps from an average of 55 fps on the settings I use.
My brother has a i5 3470 at stock with a 7770 ghz edition and has a constant 60 fps at the same res and settings in both games. I tested both pc's a couple of days ago.
