But that review where Titan sli gets outperformed cannot be right.
Why would you need 2x 780s ? Unless your playing a very high resolution
I'm not a fan of ATI as i've had many ATI cards and felt Nvidia out performs and is long lasting. It may be more expensive for Nvidia but this time since building an i7 i'de prefer to go down the route of Nvidia. In that case would you recommend 770tri over 780sli and 1 single titan?
Check out this Tri SLI, SLI and Single 700 Series Compared
SLI 780's..
TTL has a youtube review where 780 SLI outperforms TITAN SLI, though most other reviews put the TITAN above but very close to the 780.
780 SLI is also cheaper..
What do you want to do?
For gaming, 2x. 780 will outperform the Titan.
Stock Titans in SLI will beat Stock GTX 780s in SLI
Overclocked it is the same story
TTL screwed up his review comparing the Titans and GTX 780s.
Skillful TTL.
That seem more likely, though it is scary how close 780's are too TITAN (when taking price into account)..
Sorry Kapp.![]()
Guess i'll be getting x2 780's any recommend on brand or wait for 780 lightnings?
