How did you get the money?
just robbed a random armored truck got 6500![]()
Where are the Money Vans Likely to be found??
Nope. Keep meaning to watch it!
For people who have had this issue then yes installing disc 2 onto a decent/fast usb2 pen or external usb hdd has indeed solved this issue. (This is what I have read on many forums, not first hand experience as my slim doesn't even have a ROM)
Your ROM is possibly not firing on all cylinders and on its way out![]()
Awesome, it looks and plays so much better now!Where are the Money Vans Likely to be found??
I FOUND THE PROBLEM! WOOT!
Turns out it was my TV!
Ive got an LG LCD and it has a feature called Trumotion, this was set to High. I think its some kind of video processing to try and make the video onscreen appear smoother. I have no idea how to works but Im guessing it artificially messes about with the frames being sent from the source device to the TV. Maybe its to make fast moving images like movies or sport appear smoother and less laggy.
I turned this off and the lag has gone!Awesome, it looks and plays so much better now!
So happy right now. Id advise anyone else getting weird lag issues to check their TV settings, so if there is any kind of TV processing that may be interfering with the console video signal.
Going to try this USB trick also.
They're random keep an eye out, they'll get highlighted..
Red Dot on the Nav?
Just a shame as ordered now it wont come until Thursday
Yodel just arrived with my bundle.
Two ways:
1. Wait til the guards get into the vehicle, go around the back before it drives off and shoot at the double doors (middle) until they pop open revealing a silver box that falls out and pick it up!
or
2. Shoot the guard carrying the box before he gets back to the truck, pick it up, voila!
THEN GET THE HELL OUT AS FAST AS YOU CAN!
Ive just unlocked Trever ,
Anyone know where to get a parachute , I just found out the hard way after ejecting from a plane after engine failure![]()
