i7 4930k Recommended cooler
14 Aug 2012
Hi all,
I'm building a new machine and have been looking at the 4930k i7. I noticed a comment on this bundle: http://www.overclockers.co.uk/showproduct.php?prodid=BU-064-OP that says that the cooler isn't a good match.
I'm particularly concerned about the volume and would like to keep it as quiet as possible with decent performance.
I would really appreciate your advice on a cooler for this processor with the motherboard in the above link.
Thanks in advance
Matt
The mount doom wont fit with that RAM.
The Megahelms as in the Bundle is decent and allows any sized RAM to be used.
Ah. I'm just concerned that the one review states that it's loud and not entirely practical when used with that board. Would prefer a quieter cooler if possible.
These would be my suggestions:
YOUR BASKET
1 x Phanteks PH-TC14PE CPU Cooler - Blue £69.98
1 x Noctua NH-D14-2011 Dual Radiator CPU Cooler with PWM Fans £64.99
1 x Alpenföhn K2 Mount Doom CPU Cooler £59.99
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Guarantee £44.99
Total : £253.45 (includes shipping : £11.25).
I would also recommend changing the stock H100 fans for some SP120's.
This this this! Phanteks being the best cooler out of them all if you get some Thermalright TY-143 fans for it! I had my 3930k running at 4.7 on the air cooler.
