** EPIC AMD GRAPHICS CARD DEALS ALL IN ONE THREAD!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I am leaving for the USA tomorrow, so here is all the AMD deals I've done and worked on in the past few weeks which we've got left, fill your boots and get them ordered up:-
HIS HD 7990 6144MB GDDR5 PCI-Express Graphics Card @ £479.99 inc VAT
With more than twice the processing power of previous generation AMD discrete graphics cards, ATI Radeon HD 7900 Series graphics cards deliver a cinematic gaming experience and unprecedented performance.
Features:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- HD 7990 is a dual GPU card
- Core Clock Speed: 950MHz
- Core Boost Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 64 CU / 4096 ALU
- Texture Units: 256
- ROPS / Z-Stencil: 64 / 256
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 2x384 bit / 6000MHz
- Load / Idle Board Power: <500W / <3W
- Power Connectors: 2x 8-pin required
- Display Outputs: DL-DVI-I, 4x Mini-Displayport
- 2yr Warranty
Was [£529.99] Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
Gigabyte HD 7990 6144MB GDDR5 PCI-Express Graphics Card @ £529.99 inc VAT
Features:-
- AMD Golden Ticket FREE
- 3yr Warranty
Only £529.99 inc VAT.
ORDER NOW
Asus HD 7970 DirectCU II TOP 3072MB GDDR5 PCI-Express Graphics Card @ £233.99 inc VAT
The next generation Asus HD7970-3GD5 graphics card has arrived, fitted with a 28nm GPU that packs 4.3bn transistors and is combined with 3GB GDDR5 Memory, it provides users with the speed for smoother gaming. Supporting full DirectX 11, AMD CrossFireX and AMD HD3D, the GPU includes an exclusive tweak utility which allows users to tune the performance of up to four graphics cards and check card status via an intuitive interface.
This GPU Tweak function links the GPU clock frequency to the voltage, so as you scale the GPU clock the voltage automatically follows; a useful tool for inexperienced Overclockers, It also enables users to select between 2D and 3D mode by providing the ability to change the respective clock speeds, voltages and fan speeds of either. Disabling the 2D mode also forces the faster 3D mode, stabilising overclocking and benchmarking results.
Embedded with GPU-Z to access accurate graphics card information, the card also contains a live update driver and BIOS benefiting users with the ability to keep their card in the best condition. Widget monitoring provides the choice to display the most needed information including a full widget, light widget or real time monitoring.
Furthermore, new PCI Express 3.0 delivers improved encoding and twice the performance of the previous PCI Express 2.0 and vision horizons can be expanded across six displays with AMD Eyefinity technology. This technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
- Cranked 75MHz over reference for an ultimate engine clock of 1000MHz
- All new DirectCU thermal design utilizes six all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- Acclaimed DIGI+ VRM with 12-phase Super Alloy Power technology delivers precise digital power and enhanced durability for stable overclocking
- VGA Hotwire allows you to plug and solder wires on the card’s voltage regulators and accurately read and control Vcore, Vmem, and PLL voltages on a hardware level
- GPU Tweak utility helps you modify and tune clock speeds, voltages, and fan performance via an intuitive interface
- One card drives up to six screens with AMD Eyefinity™ 6
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1000MHz
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Memory Width / Speed: 384 bit / 5600MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
Was [£329.99] Inc. VAT
Only £233.99 inc VAT.
ORDER NOW
Asus HD 7970 Matrix Platinum 3072MB GDDR5 PCI-Express Graphics Card @ £269.99 inc VAT
The ASUS ROG MATRIX HD 7970 continues the ROG tradition of catering to overclockers who want the fastest and smoothest performance. It meets extreme tuning needs, utilizing a TOP-selected GPU factory-set to 1100MHz. For hardware-level overvolting, customers get VGA Hotwire and the TweakIt interface, with one-press 100% fan speed settings. DIGI+ VRM digital controllers and Super Alloy Power components form the basis of massive 20-phase power delivery. Exclusive GPU Tweak has been enhanced for ROG duty, adding GPU loadline calibration and VRM tuning to an already full range of parameters.
DIY modification of voltages on MATRIX HD 797 becomes simple by removing the need for complicated and risky soldering. Just connect wires from dedicated headers on compatible ROG motherboards to VGA Hotwire connectors on MATRIX HD 7970, after which you can change voltages directly on the hardware level through the ASUS UEFI BIOS or via the Windows-based Ai Suite II.
TweakIt provides flexible overclocking control even when gaming or running benchmarks! The + and - buttons put overvolting adjustments at your fingertips, with more power translating into the faster and smoother gaming you crave and the winning edge you require for intense multiplayer and competitive benchmarking.
Instantly trigger the dual 100mm fans to 100% speed regardless of driver settings. This proves very useful in extreme overclocking and other heavy workload scenarios where rapid heat evacuation and max cooling are a must.
The Safe Mode button resets the graphics card back to default frequencies and BIOS settings. This is a very useful feature for hardware enthusiasts and experimental tuning - think of it like the motherboard's clear CMOS function.
MATRIX HD 7970 is built with carefully-designed massive 20-phase power delivery, unmatched by any other graphics card for the ultimate in performance and spectacular power delivery. This ensures ample room for experimental performance tuning, as its DIGI+ VRM digital voltage regulation design augments precision overclocking capabilities, which are further supported by the use of hardened Super Alloy Power capacitors, chokes, and MOSFETs. These components are forged under extreme pressure and temperatures to increase reliability, power output, and overall card lifespan while eliminating bothersome choke buzzing noise, unlike much tamer reference cards. All these and more enable the absolute best in overclocking potential and experience.
ASUS DirectCU thermal design utilizes all-copper heatpipes so heat is removed efficiently. DirectCU II generates 6X greater airflow yet performs 3X quieter than reference in idle and full load thanks to dual 100mm sound-dampening fans.
A color-coded LED MATRIX indicator at the back of the ROG MATRIX graphics card gives real time and easy-to-understand visual display of the current GPU workload, with colors changing dynamically depending your card’s work load.
Easily fine-tune core and memory clocks, voltages, and fan settings intuitively via sliders or manual value entry. MATRIX HD 7970 arrives with a new ROG edition of GPU Tweak, which adds detailed GPU loadline calibration and VRM frequency tuning, allowing for the most extensive control and adjustment parameters for maximum overclocking potential.
Features:-
- TOP-selected 1100MHz cores run 175MHz higher than reference for smoother gameplay.
- All new MATRIX thermal design utilizes six all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- ROG GPU Tweak suite offers the world's first graphics overclocking tool with loadline calibration and VRM overclocking.
Specification:-
- Core Clock Speed: 1050MHz
- GPU Boost Speed: 1100MHz
- Memory Width / Speed: 384 bit / 6600MHz
- Power Connectors: 8-pin + 8-pin
- 20 Phase super alloy design
- Display Outputs: 2x DVI + 4x DP
- 3yr Warranty
Was [£379.99] Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
MSI HD 7970 Twin FrozR OC BE 3072MB GDDR5 PCI-Express Graphics Card with FREE GAMES @ £259.99 inc VAT
As AMD is going to launch its latest HD 7000 series GPU on Jan. 9th, 2012, MSI also will release R7970 TF 3GD5/OC BE graphics card at the same time. MSI has exclusive GPU Overvoltage support through MSI's Afterburner utility allowing amazing overclocked performance from the get-go. Equipped with 3GB GDDR5 memory allows for the unprecedented memory bandwidth levels needed to run today visually hottest DirectX 11 titles at extreme resolutions across multiple displays. Stability is guaranteed through the use of All Solid Capacitors making sure the R7970 have an ultra-long lifespan even under the stress of continuous gaming. DisplayPort 1.2 and HDMI 1.4a connectors allows all new audio and video formats like Blu-ray 3D Stereo, "Deep Color" (for true natural color representation) and 7.1 High Bitrate audio to be presented on up-to six displays through AMD's Eyefinity Technology.
MSI's R7900 series graphics cards are the first graphics cards in the world to support the new PCI Express Gen 3 format. With a processor and mainboard that has PCI Express Gen 3 capability, users will be able to enjoy maximized gaming performance via the ultra-high 32GB/S bandwidth. The R7900 series graphics cards have also adopted the brand new AMD 28nm graphics chip to provide higher performance computing compared to previous generation 40nm products.
MSI's R7970 graphics cards are equipped with the popular Afterburner tuning software, allowing users to adjust the core voltage and improve overclocking potential. In addition, Afterburner also features bundled Predator in-game video capture, remote monitoring capabilities via mobile phone, as well as Kombustor GPU stress testing and other amazing features at no extra charge, providing an exceptional software suite for users of the HD 7000 series graphics cards.
MSI's R7900 series graphics cards support AMD's exclusive Eyefinity multi-monitor display technology. The expanded field of view is perfect for professionals and hardcore gamers. The new MSI R7900 series cards support next-generation Display Port 1.2 and HDMI 1.4a interfaces with stereoscopic 3D capability, as well as 7.1 channel lossless high quality TrueHD and DTS-HD audio formats, providing users with the best audio and visual experience possible.
MSI's R7970 has adopted all solid capacitors. The aluminum core is capable of maintaining a high degree of stability even when working under full loads over extended periods of time. With a 10-year lifespan, MSI rids users of concerns over potential crashes or delays that are caused by system hardware overheating, further providing users with the best computing experience possible.
Features:-
- Boost Clock Speed: 1050MHz
- Memory Width / Speed: 384 bit / 5500MHz
- 3yr Warranty
Only £259.99 inc VAT.
ORDER NOW
HIS HD 7950 3072MB GDDR5 PCI-Express Graphics Card (H795F3G2M) @ £173.99 inc VAT
The World's first 28nm GPU. The revolutionary new GCN Architecture. Ready for DirectX 11.1. PCI Express 3.0. The AMD Radeon™ HD 7950 is your personal checklist for ground-breaking technology. The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better. Armed with the new PCI Express 3.0 standard, multi-GPU configurations with AMD CrossFire™ technology are just another way to obliterate the competition with the revolutionary AMD Radeon™ HD 7950. Leave no performance behind. Get higher clocks and faster gaming with AMD PowerTune technology on AMD Radeon™ HD 7950 Graphics. Fold and mine faster than ever with AMD App Acceleration powered by the unprecedented 28nm GCN Architecture. The market isn't ready for 4K video, but Radeon™ is. With full support for 3GHz HDMI 1.4a and DisplayPort 1.2 HBR2, the AMD Radeon™ HD 7950 is set for Quad HD.
- Core Clock: 800MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Was [£179.99] Inc. VAT
Only £173.99 inc VAT.
ORDER NOW
HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card (H795QC3G2M) **Voltage Unlocked** @ £185.99 inc VAT
This is the latest edition of AMD's Radeon 7950 GPU with Boost technology. What this means to the gamer is better FPS as the GPU automatically boost too 925MHz when underload to improve the gaming experience.
Features:-
- Voltage Unlocked - Great for overclocking with people achieving around 1100-1250MHz core clock!!
- Core Clock: 850MHz (925MHz Boost)
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was [£229.99] Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
MSI HD 7950 OC BE 3072MB GDDR5 PCI-Express Graphics Card (R7950-3GD5/OC BE G) with FREE GAMES @ £173.99 inc VAT
- Core Clock: 830MHz
- Boost Clock: 840MHz
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
ORDER NOW
MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** with FREE GAMES @ £191.99 inc VAT
nonl2br
<p><font size ="5"><b>Introduction</b></font></p>
<p>Leading global mainboard and graphics card maker MSI today announces the release of the R7950 Twin Frozr III/OC graphics card. This graphics card features the latest AMD 7950 chipset with 1792 stream processors and 3072MB of 384-bit GDDR5 high-speed graphics memory. The greatly improved overclocking potential and stability increases overclocking performance up to 37.5%! The highly acclaimed Twin Frozr III thermal design with 8cm Propeller Blades fan setup for 20% more air flow and 8mm SuperPipe technology is used for cooling. Fan noise of just 30dB at full load provides gamers the most silence user experience, while MSI Military Class II components are used to give the highest quality and stability. For gamers seeking overclocking potential, cooling and stability, the R7950 Twin Frozr III/OC graphics card offers the perfect solution! This Boost Edition has an impressive base clock of 880MHz, but even more impressive is the Boost clock of 960MHz out the box.</p>
<p>
<font size="5"><b>Key Features</b></font></p>
<table style="border-width: 0 0 0px 0px; border-spacing: 0; border-collapse: collapse; border-style: solid; border-color: #dcdcdc;" width="95%" border="0" cellspacing="0" align="center">
<tr valign="middle">
<td style="vertical-align: middle; padding: 4px; border-width: 0px 0px 0 0; border-style: solid; border-color: #dcdcdc;" width="150"><img src="http://marketing-uk.msi.com/images/MCII.jpg" width="150"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 0px 0px 0 0; border-style: solid; border-color: #dcdcdc;" width="*">
<font color="blue" size="4"><b>Military Class II</b><br>
<font color="black" size="3"><b>Top Quality and Stability - </b>Components tested to US Military Standards Delivering Higher OC Capability, Better Power Efficiency, Longer Lifespan!</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 0 0px 0 0px; border-style: solid; border-color: #dcdcdc;" width="5px">&nbsp;</td>
<td style="vertical-align: middle; padding: 4px; border-width: 0px 0px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://marketing-uk.msi.com/images/Propellorblade.png" width="150"></td>
<font color="blue" size="4"><b>Propellor Blade Fan Technology</b><br>
<font color="black" size="3">MSI's exclusive fan blade design generates 20% more airflow covering wider area for the better heat dissipation.Only 30dB & 66Cunder full load!!!
</font></font></td>
</tr>
</table>
<p><font color="black" size="5"><b>Full Specifications</b></font><br>
<p><font color="blue"><b>Cooling: </b></font>MSI Twin Frozr III Dual Fan Heatpipe Cooler For Maximum Cooling Potential and Low Noise</p>
<p><font color="blue"><b>Memory: </b></font>3072MB GDDR5</p>
<p><font color="blue"><b>Memory Clock: </b></font>5000MHz (effective)</p>
<p><font color="blue"><b>Memory Interface: </b></font>384-Bit</p>
<p><font color="blue"><b>Shaders: </b></font>1792</p>
<p><font color="blue"><b>Bus Type: </b></font>PCI-Express 3.0</p>
<p><font color="blue"><b>Display Connectors: </b></font>2x Mini DisplayPort, HDMI, DVI-I</p>
<p><font color="blue"><b>Crossfire: </b></font>Up to 4 Way Support</p>
<p><font color="blue"><b>HDCP: </b></font>Yes</p>
<p><font color="blue"><b>DirectX 11: </b></font>Yes</p>
<p><font color="blue"><b>Open GL 4.2: </b></font>Yes</p>
<p><font color="blue"><b>Eyefinity: </b></font>Yes</p>
<p><font color="blue"><b>Powerplay: </b></font>Yes</p>
<p><font color="blue"><b>AVIVO HD: </b></font>Yes</p>
<p><font color="blue"><b>Warranty: </b></font>3 Years</p><br>
<br>
<br>
**Latest Revision with 100% fan problem fixed, now PWM fan control works and the end-user can also use manual fan control**<br>
Only £191.99 inc VAT.
ORDER NOW
HIS HD 7850 IceQ X 2048MB GDDR5 PCI-Express Graphics Card (H785QN2G2M) @ £125.99 inc VAT
Thanks to the 9.2cm silent fan, massive amount of cool air is drawn from the central fan to cool down the GPU and graphics card directly. 2 heatpipes optimize cooling performance by removing heat from the core area, providing ultimate solution for professional gamers and HTCP users.
IceQ X is one of the quietest coolers. The card is below 28dB when watching movies, surfing Facebook, working. The card is quiet in 2D mode and remains quiet whether you are gaming, online socializing, entertaining or working.
The new architecture of the card gets more usable processing power for your money, enabling better frame rates in the latest games at high resolutions. In addition, with AMD PowerPlay™ & AMD PowerTune technologies, you can optimize the balance between performance and power consumption of your system by adjusting the engine clock during runtime of the card. Manage the power and keep your wallet loaded!
Features:-
- Core Clock: 860MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Processing Cores: 1024
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI Avivo HD
- Warranty: 2 Years
Was [£134.99] Inc. VAT
Only £125.99 inc VAT.
ORDER NOW
HIS HD 7870 IceQ X 2048MB GDDR5 PCI-Express Graphics Card (H787QN2G2M) @ £149.99 inc VAT
Features:-
- Core Clock: 1000MHz
- Processing Cores: 1280
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was [£161.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
MSI HD 7850 OC 2048MB GDDR5 PCI-Express Graphics Cards with FREE GAMES @ £125.99 inc VAT
With continued demand for increased graphics horsepower to support more visually intensive games, the AMD Radeon HD 7800 Series is set to power the next generation of games and applications. And for those looking to upgrade to a next-generation graphics card, the AMD Radeon HD 7800 Series is the ideal choice.
Features:-
- Core Clock: 900MHz
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£135.99] Inc. VAT
ORDER NOW
MSI HD 7870 Black Knight 2048MB GDDR5 PCI-Express Graphics Card (R7870-2GD5T) with FREE GAMES @ £149.99 inc VAT
Specification:-
- Twin FrozR Cooler with black shroud
- Memory Interface: 256-Bit
- HDCP Capable
- DirectX 11.1 Support
- OpenGL 4.2 Support
- ATI Avivo HD
- Warranty: 3 Years
Was [£155.99] Inc. VAT
ORDER NOW
MSI HD 7770 GHz Edition 1024MB GDDR5 PCI-Express Graphics Card with FREE GAMES @ £77.99 inc VAT
28 nm GCN (Graphic Core Next) Architecture
The new and 28nm GCN Architecture with more efficient process technology puts more transistors in less space, enabling a dramatic increase in Processing Power. Crank the settings, devastate your enemies and bear witness to absurdly high frame rates with AMD Radeon HD7000 series graphics card-DirectX 11 has never looked this good. Maximum setting and crazy performance shouldn’t be a compromise. The AMD Radeon HD7900 Series with the new 28 nm GCN Architecture assures that it’s not.
PCI Express 3.0
PCI-Express 3.0 delivers double the bandwidth per lane of PCIe Gen 2 for faster GPU (GPU communication-up to 16GB/sec in each direction), maximizing the performance from your GPU when paired with the latest platforms.
AMD HD3D Technology
Enjoy the most immersive experience possible with full support for High Definition Stereoscopic 3D, a technique that presents 2D images (movies, games, photos) in a format that creates the illusion of three-dimensional depth when using compatible 3D displays / glasses / software.
GHz Edition
The gigahertz barrier has been broken. Armed with a stunning 1GHz GPU based on the revolutionary GCN Architecture, the AMD Radeon™ HD 7000 GHz Edition (Selected model) is quite simply engineered to annihilate.
Best Microsoft DirectX11 Support
The tessellation performance on AMD Radeon HD7000 is up to 2X faster than the previous generation, and DirectCompute performance is also faster to accelerate advanced post-processing, filtering, and anti-aliasing techniques. Direct X11 games has never looked this good.
Cutting-edge Quad HD display support (4K Support)
The display resolution on AMD Radeon HD7000 series is quadrupled to the resolution of 4KX2K( 4096X2160 ) from the outputs of DisplayPort 1.2 and HDMI.
Discrete Digital Multi-Point Audio
The AMD Redeon HD 7900 Series is the first GPU that can simultaneously output multiple and discrete audio streams via HDMI and DisplayPort Output.
Enhanced Multi-GPU Capabilities
Triple or quadruple gaming power with AMD CrossFireX Multi-GPU technology. Increase your gaming performance up to 2x with AMD CrossFire technology, 2.75x for TriFire configurations, or with QuadFire configurations. With AMD ZeroCore Power Technology, the graphics card in slave modes will be switched off in idle to maximize the power saving.
AMD Eyefinity 2.0
The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better: The enhancements for AMD Radeon HD7000 series include: Stereo 3D-multi-display stereoscopic 3D support via DisplayPort 16K X 16K maximum display group resolution-output up to 268 megapixels per GPU.
- Memory: 1024MB GDDR5
- Memory Clock: 4500MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 640
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£79.99] Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
MSI HD 7750 2048MB GDDR3 PCI-Express Graphics Card with FREE GAMES @ £64.00 inc VAT
The AMD Radeon HD 7700 series is a new family of graphics cards targeting the enthusiast on a budget and mainstream users looking for increased graphics performance. It is based on the second family of GPU’s from AMD built in its new 28nm process and featuring the highly acclaimed GCN optimised graphics processing architecture. MSI introduces the worlds first HD 7000 series cards with overvoltage support! The new MSI 7750 offers you fantastic gaming performance.
Features:-
- Memory: 2048MB GDDR3
- Memory Clock: 1600MHz (Effective)
- Processing Cores: 512
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 1x DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£67.99] Inc. VAT
Only £64.00 inc VAT.
ORDER NOW
MSI HD 6670 2048MB GDDR3 PCI-Express Graphics Card @ £53.99 inc VAT
Packed with the latest GPU technologies, the Radeon™ HD 6670 graphics processors offer advanced video and display features, Eyefinity multi-display technology, as well as AMD’s 2nd generation support for DirectX® 11 to give you the ultimate in “visual immersion” for your PC.
Features:-
- Memory Clock: 1334MHz (Effective)
- Processing Cores: 480
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI, 1x D-sub
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£59.99] Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
MSI HD 6450 SILENT 1024MB GDDR3 PCI-Express Graphics Card @ £25.99 inc VAT
Packed with the latest GPU technologies, the Radeon™ HD 6450 graphics processor is a next-generation visual upgrade that delivers Eyefinity multi-display technology, HDMI 1.4a for stereoscopic (3D) displays, Displayport 1.2 as well as 2nd generation support for DirectX 11 for the most versatile solution for everyday computing.
- Core Clock: 625MHz
- Memory: 1024MB GDDR3
- Memory Interface: 64-Bit
- Processing Cores: 160
- Display Connectors: 1 DVI, 1 HDMI and 1 Anologue
- HDCP Capable
- ATI Avivo HD
- Dimension 146(L)x22(W)x94(H) mm Size.
- Warranty: 3 Years
Was [£29.99] Inc. VAT
Only £25.99 inc VAT.
ORDER NOW
MSI HD 5450 1024MB GDDR5 Low Profile PCI-Express Graphics Card @ £17.99 inc VAT
nonl2br
The ATI Radeon™ HD 5450 graphics card offers everything you need for gaming and HD home entertainment in one package. Do more on your PC with ATI stream technology, which accelerates even the most demanding applications. See more with ATI Eyefinity technology, providing the ultimate gaming experience by allowing up to three displays from a single graphics board. The ATI Radeon™ HD 5450 fully supports Microsoft DirectX® 11 which enables real-time rendering with ultra-realistic characters and incredible 3D imagery.</p>
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.</p>
<br>
<font size="3"><b>Key Features</b></font></p>
<b>Military Class Concept Components</b><br>
- SSC (Solid State Chock) has No Buzz noise and higher current for better overclocking ability.<br>
- All Solid CAP for longer lifespan.<br>
<br>
<b>MSI Afterburner Overclocking Utility</b><br>
- Support 2D/3D customized profile.<br>
- Support SLI & CrossFireX mode.<br>
<br>
<b>Native HDMI Output</b><br>
- Supports both 1080P HD movie playback and 7.1 Channel audio transmissions.<br>
<br>
<b>Low Profile Design</b><br>
- Extra Large heatsink for the best heat dissipation and zero db noise.<br>
- Work perfect with slim or smaller system.<br>
</p>
<font size="3"><b>Specifications</b></font></p>
- Low Profile Passive Silent Cooling design <br>
- Core Clock: 650MHz<br>
- Memory: 1024MB GDDR3<br>
- Memory Interface: 64-Bit<br>
- Memory Clock: 1066MHz (Effective)<br>
- Processing Cores: 80<br>
- Bus Type: PCI-Express 2.1<br>
- Display Connectors: 1 VGA, 1 DVI & 1 HDMI<br>
- HDCP Capable<br>
- DirectX 11 Support<br>
- OpenGL 3.2 Support<br>
- ATI Eyefinity Technology<br>
- ATI Avivo HD<br>
- ATI Stream Technology<br>
- Excellent for Media playback<br>
- Support DXVA & surround sound over HDMI<br>
Was [£19.99] Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
OcUK has by far the best pricing in the UK by miles on all AMD GPU's and we also have them all in stock whereas many of our competitors TRY to copy our deals and then never actually get stock.
Our prices are the best and our customer service is unbeatable!!
No problem its just not a brand I know/trust at least with gigabyte if there was a fault I know it would be there n back in a few days uk based. His mmmm I dunno hows yours doing John?
Well I've got Sapphire...which apparently comes with plenty of problems :rolleyes: However I have no coil whine and things are perfect.
I've got mines housed in a SUGO and now doesn't go above 80C and clocks pretty well to be honest, not that it needs the extra speed yet!
To be fair they're all stock gpu's with a different branding on them, so really should be no different.
I have no experience of HIS personally though but with them all being stock gpu's I imagine it's just your luck as always! :p
I am leaving for the USA tomorrow...
AMD deals right before their event on the 25th of September - hmmm
AMD is planning to unveil their latest Volcanic Islands series based Hawaii GPU chip on 25th September. AMD confirmed this report with BrightsideofNews and Semiaccurate who also report that the card would be launched officially in Hawaii.
Hawaii is a US state isnt it?
Go on Gibbo, post some pics of the event whilst your there :p
Thanks for that J much appreciated, instead of clicking the buy it now button am going to take a walk and come back to it :o:)
yeah the prices are great, shame i paid £260 for my 7950 2 weeks before they dropped :(
I'd buy another but i'm waiting to see what next gen has to offer first :)
Well as I'm still in Scotland I am unable to purchase new shiney stuff, but.....
By the time I return home Hawaii will be released......
And I may just have some spare cash lying around to get one :D
Tempted by the HIS 7950 for some CF fun. Since I try to play in eyefinity where possible I imagine this would be a good shout. Thoughts anyone? Would my CPU hold me back?
You just stay where you are sah and play nice, your not allowed to buy any new hardware until I am 10 mil in front :o:D
That walk did not help :(
If you decide to wait or go for it...either way I'm sure you'll be happy mate.
I take respite in the fact I know (ok I can't really know but we all do anyways) the next single card AMD product won't be as fast as my 7990 ;)
Plus the dual gpu solution will be reeeeeeeeeeeeeeeeeeeally expensive when it comes out!
