- 13 Oct 2011
- Melbourne, Australia
one thing guys, my 2 sata power leads i got with my corsair psu, one has 2 sata power connectors and the other one has 3, i am planning on using the one with 3 connections to power my 2 HDD's and 1 SSD, and the one with 2 connections on i was planning to power the optical drive with it, but i wont have anything else to take up the 2nd sata power connection, so does it have to be a certain one out of the 2 i plug in to the optical drive, leaving one sata power connection free on the lead?
also do i need different types of sata data leads for HDD's and SSD's? as the HDD's are 3gb/per sec and the SSD is 6gb/per sec?
You don't need to use them all, just the ones you need. They are all the same..
The ones on your PSU are SATA power connnectors, they provide the juice for the drives to work so there is no particular way around they need to be installed. So no need to worry there..
Just make sure you plug you SSD into a SATAIII (6gb/s) port on your motherboard..
