I was offered a tidy mk1 Octavia VRS at a great price a few days ago. But it had an issue with the power steering. And I couldn't tell whether it was leaking from the high pressure (I think) hose, the pump, or somewhere worse.
From the little that I can gather (doesn't seem to be much info on the internets) a rack replacement is fairly common?, and they have a very complex steering system? (this was my fear, and would have made for a very expensive and time consuming toy). It's still available, and I'm tempted. But the steering system seems rather complex. Anyone have any experience?.
Had a quick sit in a new Octavia vRS estate early. Thought it was very nice, though felt a bit dark with the black headlining. Perhaps a sunroof would be a good option?
Which broker did you use for your quote booyaka?
Its a completely conventional PAS system, and in the Golf world at least, they just dont break.
If you really wanted you could put a faster TT rack on there.
Would you be doing the work yourself?
If youre getting an Octavia as a toy then you should think about the completely worn out suspension, as that will stop your toy being as much fun
Got up this morning to find some mischevious tyke has slashed my front tyres, bit miffed to say the least.
On a positive note it gives me the opportunity to get some better tyres for my Fabia vRS as the current ones (Dunlop Sport Maxx) are/were as noisy as hell. Can anyone recommend me some 205/40/R17?
I've seen people mention:
Avon ZZ5
Uniroyal Rainsport 2
I'm probably going to change the whole lot (got the green light from the long haired general) as well.
Avon ZZ5
I'm trying to replace mine of the same size.
With the two tyres you've mentioned, I've never seen the Avons in a review against premium tyres, so unsure about them. However, the Uniroyal Rainsports have just been replaced with Rainsport 3's I thought?
I'm looking at, in preference order -
Goodyear Eagle F1 AS2's - However finding stock is seemingly difficult
Pirelli P Zero Nero - But finding it tough to find first hand views of them
Conti Sport Contact 5's
When they are all only ~ £100 a tyre, I can't see why you would pick a cheaper, lesser tyre.
