yes sorry should have been more specific!
to the side of the house is an extention that is the garage with a room above. it has a flat roof. this is what has fallen in.
we were prepared for maintenence, but not a whole new roof immediately which it now looks like it must need.
If you're going to need a new roof, it might be worth asking a suitable expert if it's possible to have a sloped roof instead. I don't know if it is, but a flat roof is an inherently bad idea in a rainy climate and you're better off with a sloped one if you do have a choice.
I suppose it's possible that the flat roof wasn't damaged by the rain. Maybe someone had gone up to check it before the sale and put their foot through it by mistake. Not that it really matters what the cause is - a hole in the roof is a hole in the roof.
While I agree that a roofer is better suited to assessing a roof than a surveyor is, I think you might be well advised to check how thorough a survey you have had done. The flat roof seems to have been rather dodgy. Maybe other things are too. A basic survey can be too basic. Given the overall cost of buying and owning a house, I think a very detailed survey is worth paying for. I paid extra to have a surveyor do everything that could be done without damaging the house (e.g. smashing the plaster off to examine the walls underneath it). I ended up with a thick report of trivialities...and peace of mind that there wasn't anything other than trivialities.
( |-| |2 ][ $;24983847 said:An over garage extension with a flat roof, that must be the ugliest thing in the world.
I don't understand why people are so desperate for extensions but will completely ruin the look of their house and street just to save a few £k.
This is what Im hoping, but I'm just sad its all going a bit pear shaped. I only asked if we could drive past because I was so excited![]()
You made an offer. It was accepted. This was 30 grand under the asking price. And now you want more??? Be prepared to be told to sling it. In this market the agent will just resell it and probably for more.
What if the property was marketed at a higher price in the first place, knowing that buyers will negotiate a lower price? The estate agent has no final say when it comes to the selling price. They can influence or persuade you to try and sell at a certain price, but at the end of the day if you want to try and sell it £30k above market value then that's what they will try and sell it at.You made an offer. It was accepted. This was 30 grand under the asking price. And now you want more??? Be prepared to be told to sling it. In this market the agent will just resell it and probably for more.
You can convert a flat roof to a pitched roof, I have done many of these in my time as a roofer.
I don't look at my roof very often, so why would I care what it looks like?
If my neighbours care, then they should pay for it. It's their issue, not mine. Why should I occur significant extra cost because of their ideas of aesthetics?
