- 14 Oct 2009
- Rotherham. S.Yorks
I had scopes apple tart in a kayfun lite last night. It was amazing. Forgot how good it was not had any in months
Fixed for you
And thanks, always happy to help.
@ Craig & Scorch, I can throw some clean bottles your way - 5,10,30 & 50 ml (will have labels on though, likely Hangsen or Scope's), you've both got my email![]()
Hmm -I had scopes apple tart in a kayfun lite last night. It was amazing. Forgot how good it was not had any in months
pic pic pic!
Accies Ambrosia = Rice Pudding, warm milk with honey & nutmeg and the slightest hint of buttery vanilla. It's wonderful and not as sweet or sickly as GVC. My joint 2nd favorite alongside Snake Oil, with Scope's Apple Tart in first place![]()
Ambrosia is what vape now if I'm out all day. Didn't take to it at first, as the favour is quite weak. But that's also its charm, its just unoffesive.
Had some Apple tart in my tank and couldn't finish it and poured it down the sink. Not sure if its gone off (3 month old) but just didn't taste good at all.
You would be more than welcome craig but i have no empty bottles either lol. There all full. Ucould send u a standard clearomiser full of it if u like I have tons of them
dual 24K Gold MicroCoil wrapped around Ocelot fur, in a Hellfire Hybrid/Caravela Versa/other Unicorn of the vaping world)...
FT replacement heads are awful, in fact unless FT are selling them as genuine Kanger heads they will be cheap copies, the wick they use is horrid. IMO of course
Yas, learn to rewick & coil the heads yourself; not just cheaper, but a much better vape. My ProTank is at 1.3 ohms and is my rock steady backup!
http://ukvapers.org/Thread-Protank-and-Evod-rebuilding
Yes I did order it. It is unique and has a hint of liquorice as you have pointed out. You know what you get some ejuices and they taste nothing like the ingredient or tastes artificial well thankfully this is not one of them. It is quite strong too. It's nice, but not a flavour I can vape all day.
It's similar to Snake Oil, one of those unique flavours which either you love or hate.
Regarding GVC - there are loads of custard, vanilla type out there. Accies, Alchemists' Egg Custard etc. I've not tried any of those....yet. Accies is meant to be creamy custard, with hints of tia maria or baileys, which is not helpful to me when describing the taste as I don't drink lol
here it is pal, expect to wait about a month for it to be in stock then delivered though mate
http://www.fasttech.com/products/0/10005773/1448300-nemesis-mod-e-cigarette-battery-compartment
A tip for Evod, Mini Protank, Protank and Protank II users, specifically those re-coiling their own heads.
I've been having some trouble lately with the heads reading different resistances or not registering on my SVD at all.
This might seem really daft or obvious but I completely missed it. The pin which you pop in the bottom of the coil, if pushed in too far, doesn't seem to make contact properly with the head of the battery you screw the damn thing in to. Teasing it out a milimetre or so seems to sort all the issues I've had!
Interesting info there mate, i just had a look at my head on my protank and its sat just a few mm's below the bit you screw the tank into your battery, i have a mini provari which i use and sometimes i find a few heads dont fire properly and they are the genuine kanger heads.
How do you tease it out a few more mm's as you mentioned above? is there some sort of method to do it??
I have a question R.E. VW devices, am I right in thinking that with a VW mod, I can more or less forget about trying to hit exact ohm figures in my home made coils? I mean just concentrating on getting the coil even and close enough to my desired resistance and letting the device sort the wattage?
I had the same problem with my old Protank, constant no connection issues, i ended up using a bit of card between the rubber bung and centre pin, this allowed the centre pin to just sit past the threads and i didnt get any leaks.
As far as the description said, they were genuine. Cant cancel the order now as its been shipped so its just a case of having to wait now lol.
It's all good even if they're rubbish copies - you'll have plenty of stock for rewicking/coilingDon't throw away your old heads. I actually like the FT replacement EVOD heads better than the Kanger ones. Once you remove the crap coil and wick and add your own, they're perfect.
RedMogg - I tried a bit of cotton wool wick, nearly had a vapegasm. Did it a bit wrong though, got a bit of leaking and flooding going on now. Might have another go later. It's like chasing a heroin rush, only a bit cheaper. Arguably more destructive, productivity wise, though![]()
