correctedI only really have a problem with people making out like we live in a country that has snow on the roads for months on end. I don't.
corrected![]()
I did almost put (I), but there is no a shortage of 'winter tyre' threads on this forum and I'm definitely not the only one that's had a pop at people who exaggerate the amount of snow we get
But as I've said, if someone can justify the cost (rural roads, hills) then I don't have a problem with it. I've even considered them myself over the last few winters. It's just that for the vast majority of the year they offer no real benefit over summer tyres.
Who knows, maybe this winter I'll even justify them to myself![]()
- plus, as I say, the temperatures go sub-zero out here (a lot of dips and valleys) and any extra traction adds to my fun drive to work (the last 5 miles are single-track roads with most of the people not understanding passing places)
Nope you are correct there is not a Winter apocalypse, it can be bad though.
The last winter was bad, the one before was fine even though outside temperatures were down to -7C in places most days Nov - Feb, and below 10C until April
I work in the middle of nowhere - there was snow on the roads (maybe not falling every single day) and it was compacted so well that even gritting would not clear it. The road shown in the clip was clear for probably a third of the time, with snow in the hedgerows
They are not easily avoided if your place of work is on the middle of an untreated/rural road
Anything below 7C and they are better than Summer tyres
Hi,
After some Winter Tyres for the Doris for her ford Ka 2013 model.
Not sure what size they are I think 15" but can anybody recommend some good tyres for Snow/icy conditions.
ta
[TW]Fox;25001430 said:Winter tyres need changing at 4mm, why on earth would you buy part warns with 4mm of tread!?
Winter tyres are more aimed at people living in Sweden. You don't need them here. Majority of roads are gritted and those that aren't, are easily avoided.
[TW]Fox;25000880 said:Until white stuff contacts the ground, I still genuinelly beleive the best tyre to have fitted to your car in the UK is some sort of UHP premium brand tyre with a focus on wet weather performance.
Once there is actually stuff on the ground it changes completely and said tyres become useless and winter tyres make a mockery of them. The choice is therefore simple - if you fear being stranded by snow, fit winter tyres and remove the fear. If you don't, then don't. The 7c thing is an irritating sideshow, IMHO.
[TW]Fox;25000880 said:This is simply not true but you cannot be blamed for thinking it is given how often this useless and meaningless stat is repeated by advertising material and promotional material. It makes absolutely no sense that there would be an exact temperature at which every single tyre of a certain type irrespective of performance, quality, brand or construction would suddenly become worse than every other tyre of a certain other type irrespective of performance, quality, brand or construction. Until white stuff contacts the ground, I still genuinelly beleive the best tyre to have fitted to your car in the UK is some sort of UHP premium brand tyre with a focus on wet weather performance.
all this from a question about winter tyres - why do we bother...we should all drive round on Summer LingLongs - just more carefully
It would save so much money for everyone and there would be fewer accidents
. It may well have been the AWD + Snow Mode that got the thing moving rather than the tyres ... but jump on the brakes and you definitely knew you had winter tyres on it! There's a hill round here that in the snow the only other vehicle to come up it was an Audi A6 with Quattro... but coming down it he was just a locked-up as everyone else on Summer tyres.
.the properties out of the snow will be the same as a 5/6mm tyre.
