No I meant in the standard Prodigy, the ITX one. I'm not sure about the Prodigy M.
I've seen builds in the ITX with the rad up top so you only lose your optical drive bay. Or in the front and then you lose all your bays.
 and itll fit all my hdds, im not bothered about Optical drives at all, i'll use an external
Hmm interesting idea. Could work well, especially on the Prodigy/M because it has the handles up there anyway. Could probably even manage a push pull with 1 row fans inside, and rad and 2nd fans outside? Would you do exhaust or intake blowing warm air towards the GPU?
Defo have to do a build log
Yep 2 fans each side of the rad is the basic gist of it. I don't think push pull is strictly necessary but I believe it can reduce temps by a couple of degrees sometimes.
With regard to intake vs exhaust, logically as you say you want hot air being exhausted out the top, but logic doesn't always seem to apply with case cooling.
The generally recommended thing is to try it both ways and see, and then report back
But yeah I'd make a new post in the cooling section like you say.
Wonder when the Prodigy M will be in stock.
I'm loving the gold bitfenix hows this -
I don't see any room for improvement here but possibly the psu? u sure you want 550w? Maybe you can pay a short amount more for a higher psu and make ur system 'future upgradable'
It's not a big factor as i said there isnt any major room for improvements, thats a good setup
That Seasonic is an excellent PSU and a cracking deal on this week only.
But the only reason you need that much juice really is if you're running SLI/Xfire at the moment. Which you can't do on an ITX system.
Obviously you never know how much power a future single GPU is going to draw, but they are generally getting more energy efficient at the moment. The Titan is one of the most energy efficient cards available I believe. How are the new AMD's that have just been announced for energy efficiency, as that's never been AMD's strong point?
At the moment there is a fundamental limit on how much power a card can draw through the PCIe power connectors and motherboard. So you'd potentially have to purchase molex to whatever new pinout they create to power any hungrier cards that are created in the future anyway.
That's not to say it's a bad idea. It is a cracking PSU and would power a new SLI/Xfire rig if the mood ever took you. You could swap to a Prodigy M and just buy a new mATX motherboard and 2nd GPU in the future if the PSU was already capable though I think it does only come with two 6+2 pin PCIe connectors
I love the 350D seen some clean builds in that.
Is it worth bumping the PSU to give you SLI capability for the future if you're going full ATX and an SLI board?
YOUR BASKET
1 x Antec High Current Pro 750W Modular '80 Plus Gold' Power Supply £129.95
1 x Antec High Current Gamer 750W Modular '80 Plus Bronze' Power Supply (0-761345-06223-7) £99.95
Spanner in the works?
YOUR BASKET
1 x Asus Z87 MAXIMUS VI GENE Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £169.99
