http://cdn.overclock.net/f/fc/900x900px-LL-fc3d3ed2_8a5dba6c_1446253.jpeg[IMG]
What i did to my matrix.[/QUOTE]
Wow you're cool.
Wow you're cool.
What exactly are you getting out of this "Supperior" design?
Wow you're cool.
Thank you thank you. It now looks like a chair lol.
There's no point in saying anything, as you're just going to rant about how awful it is whatever anyone says...
Got to ask - what happened?
How does that strengthen your case? If anything it will make people less inclined to listen to your views, whether that are valid or not. Assuming it was a full working card it is an irrational thing to do with something of value.
Why wouldn't they RMA it?
It wasnt working, it started artifacting on stock all of the sudden, couldnt get it RMAd so i broke it and got a reference card. Best decision i ever made.
1. Better PCB.
2. Better compatibility for waterblocks.
3. Use the oc software of your choice and not the forced to use GPU Tweak.
4. VRM sensors.
Did you overclock it too far? Was the memory getting too hot and this is why it ended up artifacting at stock?
The golden rule is to return the card like it was new and everything in tact and they would have replaced it. I can understand your frustration but lots of recommendations for the Platinum and Top variants from other users, it is hard to sway the OP to your way of thinking when he has looked about at other reviews.
I say go for the DCII Top OP, as that is a cracking deal on a cracking card
very well said. if he didnt modify the card he would get a replacement card, problems solved. even in ref cards, it is possible to have a faulty unit and you cant go round saying they suck because yours was faulty...
THANKS to everyone who contributed. i will be getting the DCII TOP. it has 8+6 pin connectors according to OC description and at £240 is dead cheap. hope it all works out.
Thanks everyone!
Well teppic? Dont make a claim without backing it up. Its one of the stupidest things a man can do.
