Considering an 8350... Am I as mad as a brush?
I've sometimes gone over budget (pointing it out clearly) if someone can get something massively better for just a little bit extra. Lots of people put up a budget and then 5 posts down add £50 to it.
As to 8350 cooling - you can get to 4.5GHz with a £25 cooler.
easy, this one got me 4.8 no problem on the one I just shipped off to its owner.
Thing is teppic, if I know I am overclocking a chip (which is what is pretty much a given on these forums) I would want a quality cooler on it. The new built in liquid cooling is great considering this was not around the last time I built, so a £40 cooler of this sort would be just as essential as the decent PSU.
I may be anal about it (a tenner or just over that is acceptable) but a few guys seem to recommend a product as its what they have or follow the sheep especially when it's a chance to pop the under budget AMD offering I have noticed.
4.8GHz is impressive on a £30 cooler. I think the newer 8350s must really be clocking well.
I helped someone with a spec a couple of months ago and he wanted this cooler:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-CM
He could get to 4.6-4.7GHz on that.
~4.7 on that cooler I would say is good going.
That is a decent cooler, but the one I linked is twice the physical size and has twice as many fins.
I don't know whats happened, but since Richland the FX-8 series CPU's do seem to clock that bit better and run that bit cooler than the initial tested ones all over the net.
Would have been interesting to see what that one you had at 4.8GHz would have got to under water or a high end air cooler - sounds like 5GHz would be no trouble at all.
Not mad at all check out my thread cant get 8350 past 4.6 ghz I did upto 4.8 @ 1.43v and still head room on temps cinebench score of 8.21 and will be posting gaming benchmark tomorrow
8350 for the win
8350 for the win
If you had the sabertooth or formula MB you could probably get it to 4.8 or even 5 stable with no problems.
Thanks again guys. I probably will get AMD when I upgrade. Is there any reason to get an 8350 over an 8320?
It's possible (certainly not definite) that you might get a higher overclock on the 8350. Aside from factory clocks it's the same CPU though.
I would get the 8320 there isnt much difference between them if there was a smaller price gap like when i got mine i would say go for the 8350 but thats not the case.
Forgiveness which skip with this, but it goes a bit with the theme. It's well worth the 8350 or better 8320? I understand that they are the same CPU, but blocked the 8320?
I'm going has purchased one recently and was not by which of the two go ...
