- 14 Mar 2011
Hhhmmm I might leave the optical for now. The SSD is more important anyway. Every time I look into what SSD to get I get nowhere. Looked at SanDisk's Pulse/Ultra/v300 range which seem to do well but then I hear stories of their reliability not been great. Then some friends said if I can get one in the same price range with something other than a SandForce controller - go with that. Decisions, decisions.
I think the Crucial M4 or Samsung 840s seem to get the most praise (have an M4 myself)...
On the ports front you could have course add a card which gives you some extra SATA ports? (Unless you're using all your card slots for other things)
Or another crazy idea - could you mod an external USB optical drive to be an internal one which still uses USB? If that worked you could just loop a cable from one of the rear USB ports back into the case
p.s. Did you ever get your 40mm fan?
- the fan wasn't in the box initially so OcUK sent another with Royal Mail. 6 days later, still nothing. The tracking number provides no useful information other than "progressing through our network". OcUK have sent another. Third time lucky.
] ... I'm still looking forward to seeing how your fan mod goes
The last thing you want to do is break something by trying to do the mod in a hurry... and I imagine it'll be the last thing you want to do when you've just moved (I know I like to spend a good few days getting everything in its place)
