This weekend Only Deals - Corsairs SP120 Fans and the AWESOME Asus 7970 MATRIX Platinum!
20 Jul 2009
The bleak North East arm pit of Britain
Today only we have some Corsair SP120 fans as well as an absolutely EPIC price on the Asus 7970 MATRIX Platinum.
Corsair SP120 Performance Series High Pressure - Dual Pack (CO-9050008-WW) @ £19.99 inc VAT
The advanced design of the SP120 provides the higher static pressure that radiators and heatsinks demand, while maintaining a quiet noise profile. Seven ultra-wide, custom-molded blades deliver high static pressure, and the customized fan enclosure helps airflow move in the right direction. The rubber mounts and the advanced hydraulic bearing system combine high reliability with low-noise operation. Three included colored rings allow you to customize the look of the fan to match the rest of your hardware.
High Static Pressure for Efficient Cooling on Radiators or Heatsinks
Cooling today’s high-performance PCs is a complex task, and a single fan design can’t meet every need. The fan you use to exhaust hot air out of your case might not be the best fan to mount flush against a heatsink or radiator.
Static pressure is the measure of how well a fan can push air in this type of highly restrictive environment, and this is where the SP120 excels. It’s an ideal solution for radiator and heatsink use, as well as drive bay intakes, and other locations where you’re mounting a fan directly adjacent to a heat source.
For high-volume cooling in less restrictive environments, like case exhaust or side intakes, check out our AF series of high-volume fans.
Size: 120mm x 25mm
Operating Voltage: 7V – 12V
Performance at 12V
Airflow: 62.74 CFM
Static Pressure: 3.1 mm/H20
Sound Level: 35 dBA
Speed: 2350 RPM
Power Draw: 0.18 A
Was £25.99 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
And then this little beast :cool:
Asus HD 7970 Matrix Platinum 3072MB GDDR5 PCI-Express Graphics Card **FREE SHIPPING** @ £249.95 inc VAT
The ASUS ROG MATRIX HD 7970 continues the ROG tradition of catering to overclockers who want the fastest and smoothest performance. It meets extreme tuning needs, utilizing a TOP-selected GPU factory-set to 1100MHz. For hardware-level overvolting, customers get VGA Hotwire and the TweakIt interface, with one-press 100% fan speed settings. DIGI+ VRM digital controllers and Super Alloy Power components form the basis of massive 20-phase power delivery. Exclusive GPU Tweak has been enhanced for ROG duty, adding GPU loadline calibration and VRM tuning to an already full range of parameters.
DIY modification of voltages on MATRIX HD 797 becomes simple by removing the need for complicated and risky soldering. Just connect wires from dedicated headers on compatible ROG motherboards to VGA Hotwire connectors on MATRIX HD 7970, after which you can change voltages directly on the hardware level through the ASUS UEFI BIOS or via the Windows-based Ai Suite II.
TweakIt provides flexible overclocking control even when gaming or running benchmarks! The + and - buttons put overvolting adjustments at your fingertips, with more power translating into the faster and smoother gaming you crave and the winning edge you require for intense multiplayer and competitive benchmarking.
Instantly trigger the dual 100mm fans to 100% speed regardless of driver settings. This proves very useful in extreme overclocking and other heavy workload scenarios where rapid heat evacuation and max cooling are a must.
The Safe Mode button resets the graphics card back to default frequencies and BIOS settings. This is a very useful feature for hardware enthusiasts and experimental tuning - think of it like the motherboard's clear CMOS function.
MATRIX HD 7970 is built with carefully-designed massive 20-phase power delivery, unmatched by any other graphics card for the ultimate in performance and spectacular power delivery. This ensures ample room for experimental performance tuning, as its DIGI+ VRM digital voltage regulation design augments precision overclocking capabilities, which are further supported by the use of hardened Super Alloy Power capacitors, chokes, and MOSFETs. These components are forged under extreme pressure and temperatures to increase reliability, power output, and overall card lifespan while eliminating bothersome choke buzzing noise, unlike much tamer reference cards. All these and more enable the absolute best in overclocking potential and experience.
ASUS DirectCU thermal design utilizes all-copper heatpipes so heat is removed efficiently. DirectCU II generates 6X greater airflow yet performs 3X quieter than reference in idle and full load thanks to dual 100mm sound-dampening fans.
A color-coded LED MATRIX indicator at the back of the ROG MATRIX graphics card gives real time and easy-to-understand visual display of the current GPU workload, with colors changing dynamically depending your card’s work load.
Easily fine-tune core and memory clocks, voltages, and fan settings intuitively via sliders or manual value entry. MATRIX HD 7970 arrives with a new ROG edition of GPU Tweak, which adds detailed GPU loadline calibration and VRM frequency tuning, allowing for the most extensive control and adjustment parameters for maximum overclocking potential.
Features:-
- TOP-selected 1100MHz cores run 175MHz higher than reference for smoother gameplay.
- All new MATRIX thermal design utilizes six all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- Acclaimed DIGI+ VRM with 12-phase Super Alloy Power technology delivers precise digital power and enhanced durability for stable overclocking
- VGA Hotwire allows you to plug and solder wires on the card’s voltage regulators and accurately read and control Vcore, Vmem, and PLL voltages on a hardware level
- GPU Tweak utility helps you modify and tune clock speeds, voltages, and fan performance via an intuitive interface
- One card drives up to six screens with AMD Eyefinity™ 6
- ROG GPU Tweak suite offers the world's first graphics overclocking tool with loadline calibration and VRM overclocking.
Specification:-
- VOLTAGE UNLOCKED!
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1050MHz
- GPU Boost Speed: 1100MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6600MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 8-pin
- 20 Phase super alloy design
- Display Outputs: 2x DVI + 4x DP
- AMD Golden Ticket: Choose any three games from AMD (Select 3 FREE Games from AMD upto December 31st 2013)
- FREE Shipping: Buying this product entitles you to FREE SHIPPING on your entire order!
- 3yr Warranty
Was £269.99 Inc. VAT
Only £249.95 inc VAT.
ORDER NOW
Any deals for the PWM version or quiet edition?
I want a pair to go on my h100, if i plug these in to the head unit will they spin at max rpm or will it be variable based on which setting i have selected on the unit?
Wake up earlier Andrew Moore! :(
28 September 2013 08:35:16 - Order Confirmation including:
2 x Corsair SP120 Performance Series High Pressure - Dual Pack (CO-9050008-WW)
Might go try ply 5UB in CS section :D
Hey guys, possibly looking into get two of these 7970 bad-boys.....but need a question answered thanks.
Would my system bottleneck with 2 of these cards??
*OVERCLOCKED* Intel Core i5 750 2.66Ghz @ 4.00GHz / Gigabyte GA-P55-UD5 Intel P55 Motherboard / Corsair XMS3 4GB (2x2GB) PC3-12800C9 1600MHz DDR3 Bundle
thanks in advance
That 7970 is tempting.
Too bad my i3 will bottleneck, I guess I'll have spend some extra cash now that Haswell is out, oh, the choices I have to make sometimes.
But with AMD's new graphics card line up coming soon, not sure if I should wait.
Damn it very tempting on the matrix, will I see any performance improvement over a xfire 6950(unlocked to 6970)?
Been planning on holding out on the graphics card upgrade as have just spent little over £400 on the Asus Maximus vi formula plus 4770k to upgrade my current 2500k system.
In short, yes. Even at 1GHz, the 7970 is often over 50% faster than a stock 6970, sometimes even 100%. And these things can get to 1200-1300MHz. Add in the extra memory, bigger bandwidth, vast improvements in GCN etc.
Just to be clear I have 2x 6950(6970), so you're saying 1 of these will be faster?
By the by I have a dell u2711 monitor.
I'm saying that a stock 7970 GE can be up to twice as fast as a 6970, and the Matrix already comes at a higher speed than the stock one, and can go a lot further. Crossfire isn't 100% scaling. An overclocked 7970 will give you near, equal or better speeds depending on the game, but the increase in memory and memory bandwidth is also important looking forward. And you get Mantle support.
Ive still got the Direct CU non matrix sitting unopened at home bought for £234 i can seem me taking advantage of OCUKs 14 day satistafaction guarantee shortly I ts a bit annoying to see a this week only offer get cheaper a couple days after youve bought it.
I'm sure they will just give you the difference if you ring them. Although lets be honest here, you were happy to pay £234 for it when you bought it so you have jack to complain about really. But like i said they will most likely give you the difference if you ring them or post in the customer service section.
It only lets you pick one card, if you try for two it tells you just above the checkout logo. When you click buy two.
Or am a doing something wrong??
I did read in one of the other threads someone had a similar issue, and one of the staff said to just order another as a second order as it's free delivery, not 100% whether this will apply in your case as I haven't purchased two.
Give it a try.
This week only makes you think your getting it as cheap as itll go for at least a few weeks that was my point
£8 is no big deal and not worth returning it for but I dont think its right prices being cheaper after the this week only deal has ended.
