So it's the middle of the week, and the weather's miserable - but here's something good from Overclockers UK!
That's right folks, it's time to give your system an upgrade! Grab a new graphics card, or go SLI, and whilst you're at it, grab some more RAM!
Bonza!
Inno3D GeForce GTX 780 iChill HerculeZ X3 Ultra 3072MB GDDR5 PCI-Express Graphics Card @ £539.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 1006 MHz
- Core Boost Clock: 1046 MHz
- Memory Clock: 6212 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Only £539.99 inc VAT.
ORDER NOW
__
Crucial Ballistix Sport Series DDR3-1600, CL9 - 16GB Kit (BLS2CP8G3D1609DS1S00CEU) @ £79.99 inc VAT
Crucial Technology Crucial 16GB kit 8GBx2 DDR3 1600 MTs PC312800 CL9 15V Ballistix Sport UDIMM 240pin BLS2CP8G3D1609DS1S00CEU Components Memory.
Specification:-
- Module Size: 16GB kit (8GB x 2)
- PC3-12800 DDR3 240-pin DIMM
- Bus I/O Configuration: Unbuffered
- Memory Latency: 9-9-9-24
- Error Correction: Non ECC
Only £79.99 inc VAT.
ORDER NOW
Bonza!
Features:-
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
ORDER NOW
__
Specification:-
ORDER NOW
Especially as you've got the brilliant Sabertooth board on this week offer.
