- 21 Apr 2006
I bought a Samsung 840 Pro yesterday to put windows 7 on.
The first install kept erroring during the first update. After repeatedly applying the updates, and after multiple resets. Things finally seemed to be ok.
I noticed that I'd put the drive in a sata2 port, so switched it to a 3. This caused windows to take 1 minute+ to load up. After messing around trying to get it working, I gave up and reinstalled.
Second reinstall had the same issues as the first. Also, any large download would be corrupt. If I save the download to a normal HDD it's fine.
I have had a couple of freezes too (a reboot sorted them out.)
The Samsung Magician software is showing everything as being ok (and the speed of the SSD is great.)
I'm not OC'ing and have had no issues prior to yesterday morning (so don't see it being a memory or hardware issue.)
Should I just RMA the SSD? Are there any tools I can use to properly test it?
