The only GPU that's faster then a 7970 is the 290XT and that 3x more expensive.
I hold the record for the highest overclocked Phenom 2 x6 1075T registered on HWBot in the UK.
7970s have took a little plunge this week
id save your money and get two of the cards suggested (7950s) most will surpass stock 7970 speeds and have very good coolers.
best bang for buck gpu/gpus.
There is a company call NVidia that make fast graphics cards as well.
I don't think they'll drop further.
Trying to decide whether to pick up a 7990 or another 7970.
Used to run 7970's in crossfire, but had issues with microstutter, so not sure if I'll bother with either currently - does anyone know if the 7990's suffer microstuter, or whether its gone due to them being on the same board?
That only applies for the Nvidia 256-bit 2GB cards vs the AMD 384-bit 3GB cards. There's no performance disadvantage for cards like GTX780 at higher res as it as 384-bit and with 3GB of vram (plus the greater GPU grunt).from what I have read, they aren't as fast at higher resolutions?![]()
^^^^ as good as a amd reps reply![]()
Is matt an amd rep yet?![]()
Matt if that is what you look like then I could be persuaded to ask certain people.
