Cheers. I'm still not very good at warding atm and the games I'm in are obviously extremely hit n miss as far as the team warding goes since I'm still not level 30. I do sometimes grab a ward or 2 to put in the river bushes but not often enough and not pink wards.
I haven't really been roaming enough either (partly cos of the above, partly cos I usually can't pressure the mid lane enough and partly cos I just don't know when to take advantage yet). I have managed to pick up some kills by doing it at least.
I do sometimes get the combo a little wrong. Mostly it would be trying to Charm while too far away so it misses or throwing out the Orb and Spirit Rushing to a position where the return misses or something similar. My biggest problem is definitely the DFG though since I can never seem to get that right >< Do item casts need any sort of animation or can you do them at any time so long as you aren't CC'd? If not then its purely because I'm trying to do it out of range and really need to learn the DFG range better ><
Green wards will do, unless you planting in a place where wards are usually planted. For example - baron. You should never Baron without a pink ward never as a general rule, a green ward won't show other pink wards around. That's the main difference.
You'll find that when playing with lesser players that they won't generally ward too much - A lot of them just leave it up to support to ward which isn't the right thing to do. Yes supports ward, but only for the ADC within the initial phase before brancing out when the lane phase finishes.
For example, taking Ahri mid, you should start out with a crystaline flask, sight ward + health pot. That's certainly what xPeke starts with. It gives you a bit of sustain (Ahri is very mana heavy) but allows vision for the early ganks by whomever is jung. It's improtant that you find the location of the jung as soon as you can and place the ward where they will be travelling - you don't want to push your lane and get caught with the jung coming up behind you for example. Especially not until Ahri/Kass gets their ulti.
So, roaming really depends on two things - vision of where you're roaming too and enemy position. There's not much value in roaming to bot lane if bot lane are under their own tower for example. There's also no real value in roaming when it's heavily warded unless bot lane are pushed up all the way. Make sure you roam where you can see, you don't want to facecheck the enemy jungler, or the mid laner and the jung. When on red team, I went to gank down behind the dragon pit (so on the land) and put a ward behind the dragon in the bushes. I like to see where the enemy jung especially is roaming around. As a mid laner you should have a bit of money spare, as you should be getting kills + decent farm.
Item casts are generally instant, it'll take soem getting used too. Some items require you to really use smart cast as well - get into that habit as it's a good one to have.
Don't worry to much about pressure on mid lane, certainly don't worry yet about pushing the mid lane. Generally as Ahri, her Q will farm (make sure you get the creeps early so theyare in a line already, but also get her W of on the enemy champ regualarly. You want to harass the midlane without leaving your self open if you can, this allows you to use 'plays'. Ahri has a huge damage burst especially around the combo and her spirit rush allows you to get out of trouble as well. Once you hit level 6 you should be looking at bursting and harass and killing. Even if y ou don't get the kill, you'll send the enemy mid back to base allowing you to free farm (with the appropiate vision up).
What order are you maxing Ahri's abilities btw? Xpeke starts with W first, then Q, then W, then E, then usually adds another to Q then the rest to W, then Q and finish off with maxing E last. Obviously adding a point to R everytime you can
Check out xPeke's vids on youtube, he explains things as well (though usually over voice chat to whomever he is playing with) but it allows you to see how he plays Ahri and he's very very good at her obviously! He also brings good habits onto you, like timing flash of the other midlaner for example.
I'm no expert, I don't even play Ahri too much (though I am learning her!), I just watch a lot of LoL videos and try to learn as much as I can through others. Anything which anyone disagrees on, feel free to point it out to me, happy to learn from others who are more experienced
