Permabanned
- 8 Jan 2010
- UK
any news on the bobas group buy yas?
So im correct in assuming that the less coils i have round my wick, the lower the ohms??
Honestly no idea, it's the one that comes in the starter bundle from Vapemesh and all is says is 0.2 on the sticker that was on the side.
was that meant for me?? because if it was then i have absolutely no clue what you are talking about
Correct, with 28awg you can do 10 wraps on a 1.5mm diameter coil to give 1.6ohms. Think its about 6 wraps on 32awg to get the same ohm.
0.2 is 32 awg.
0.2 is 32 awg.
Lovely stuff smokedog, im using the 3mm ekowool at the moment so i guess going up to 6 wraps on that wot give me anything but a silly high ohm reading??.
Actually thinking when i first did my coil and wick earlier today, i did wrap at 6 coils and got 3.3 ohms and didnt work for me.
Think im going to have to trial and error my way around the wraps and ohm readings as 2.4 is just a bit too high, ideally i would like to get around 1.8ohms.
OH ****! Re-coiled my RSST this evening and it's all gone a bit Pete-Tong...pulsed on my ego, so no hot-spots, filled with juice, plonked on my SID @ 4Volts, checked again, whole coil went red so damn fast and then set fire...oops...tried at 3.5, same, 3V and it tastes funky...switched to Watts, nothing is going well on it...give up for tonight, will attempt again when I get home later today...I'd like to point out, I used 0.2 Kanthol and it came in at 1.3 Ohms...
Vaping King (Who you obviously know) are good, aside from Scoope and GVC they are my 'go to' supplier.
Guys can you recommend a good juice supplier that I can get all I need in one place. I have only used yorkshire fog so far but would like some monkey jizz and a couple of other highly rated ones.
thanks
cuffylad is after an "one-stop-shop" for all his ejuice needs. No such vender exist "yet". Also I can see this could be difficult, as most of these guys make their juices to order.
Speaking of shopping...... Kayfun Lite.
After messing with the RSST and finding that i do have a bit of patience to play with these things, I quite fancy one.... Might have to join the ranks.
It will be the best vaping money you ever spent. I've been using my solidly for 2 months. All the other attys I own is gathering dust.
