**Official Unigine Valley Leaderboard**
Single EVGA 780 Classy HC 1430/3944 cpu 3960X @ 5.2
Corsair Dominator 16Gb 2400 9-11-11-31-1T
The HC blocks were a separate buy and stuck on later. Not the best design but (for me anyhoo) better than the air coolers.
Have you thought about posting a score on the Heaven 4 thread.:D:)
Impressive overclock on a 3960X... What sort of volts are you running that on?
Many thanx
Thanx for the feedback guys (and gals?).
Thanx "Humbug". Never thought about the IMC.
I think that's my limit "Gregster". I've stolen......... err I mean borrowed........ an EVGA HC Titan off a mate so I should be able to see what's left in my setup, if there is more (maybe :) ) to come out of the graphics.
"Stephenb", I have an EVBot connected to the card so I can go all the way up to 1.5v on the core........with the HC block on. I have a "Skynet" bios loaded as well which allows higher power limits, but even with the 1.5v (1.8v if you get finger trouble) does not let me go above 1425. Some EVBot owners are going above 1500 but, obviously, there's more to it than just owning an EVBot :).
"Kaapstad". I was off to have a go at Heaven4 later today.
Errrrr......1.58v :eek:.......but it's only for bench runs, and it is water cooled, and I don't need cooling fans living in Blackpool. I just hold the radiators out of the window. :D.
To Prime, the limit is 4.8-4.9 GHz at about 1.4Vc :).
1.58v :cool:
I need 1.475v for a stable 4.9GHz on my 3960x
Max voltage I've pushed through mine running the odd benchmark is 1.5v although would go higher if I were running some top notch water cooling setup.
[email protected]
7970CF@1250/1800
Score = 4322
