Hi there
Some more pimpage of the awesome and stunning looking Sapphire R280X Toxic from Sapphire:-
Sapphire Radeon R9 280X Toxic OC 3072MB GDDR5 PCI-Express Card @ £269.99 inc VAT
The SAPPHIRE R9 280X TOXIC features SAPPHIRE Vapor-X technology which is a sophisticated integration of digital power IC, DirectFet, and four new Black Diamond heatsink chokes on a high density 10 layer PCB. This technology is capable of supplying 60 Amps power per phase on demand, which is 20 Amps more than the HD 7970 reference design. With a suitable PSU! Compared to the reference board, Sapphire's Vapor-X technology provides more headroom for overclocking with a power efficiency of over 90%. Sapphire provides efficient power whenever the GPU needs it.
The new Tri-X cooling technology is a combination of the optimized cooler module, new 10mm heatpipe and Triple fan. As a result, the new cooler is 20% quieter than the previous Toxic HD 7970 GHz Edtion.
Key Features:-
- Triple Fan cooler, 30% more airflow and 20% quieter than the previous Toxic HD 7970 6GB card.
- Optimize dual module design, the new fin and heatpipe placement improves the airflow offer 50% more efficiency in heat dissipation.
- Anti-Dust bearing, Enhance the reliability for the fan cooler.
- Memory cooling, the cooler module also cools the memory chip for the best stability and offers more OC headroom.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 1100MHz
- Boost Clock Speed: 1150MHz
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6400MHz
- Power Connectors: 8-pin + 8-pin
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- Product Review: http://www.kitguru.net/components/graphic-cards/zardon/sapphire-r9-280x-toxic-edition-oc-3gb-review/
- 2yr Warranty
Only £269.99 inc VAT.
ORDER NOW
Check out the Kitguru Review, it beats all other R280X for performance out the box and when you overclock this bad boy, it is right on the heels of GTX 780, but at £200 less makes this card an absolute bargain, read the review for yourselves:-
OcUK will be first with stock and potentially the only Etailor with stock for a while as we were first to order in the UK.
Key Features:-
Specification:-
- Power: 250W TDP
- 2yr Warranty
ORDER NOW
