If a product does not meet my expectations it goes back. End of.
I would have those expectations because I paid for them. So for example, when I bought my first 8 core AMD I wanted 4.2ghz out of it and I got it. Had I not? I'd have sent it back.
OCUK don't feel bad for selling the CPUs 8 pack has turned down and charge a massive premium for those that he has found very capable, so why on earth would you feel bad at all?
I think in the UK people have either very low expectations or, are simply too sheepish when it comes to sticking up for themselves and having expectations.
Haswell chips are really pretty poor. The review samples ALL hit good clocks with half decent temps so Intel were cherry picking themselves. And quelle surprise, they got decent reviews. I doubt very much if an I7 had gone out that wouldn't go over 4.2ghz then it wouldn't have got the reviews.
FFS people stop being so spineless.
It varies depending on what you are doing but the things I've tested and seen it's not quite that much. Check your own Cinebench score of your 2600k at 4.8Ghz and you will see that it's pretty much the same as Haswell at 4.4Ghz, ~850cb.from what ive seen with benchmarks its roughly 300mhz with each gen
ivy 300mhz over sandy and haswell 300mhz over ivy ect
If you had Performance Tuning Protection Plan you could blow the CPU and get another![]()
It's not reasonable to keep DSR'ing CPUs just because you got stuck with a turkey of a CPU for overclocking. The CPU is fit for purpose at stock speed, neither Intel or OCUK make any guarantees in relation to a minimum overclock. You pay for the ability to overclock which you have done and got to 4.2Ghz, your not happy with the overclock, well that's too bad, maybe it's your motherboard, your ram, your psu or something else that is holding your overclock back.
If people routinely abuse the DSR then it will be taken away. It was probably bright I to encourage online sales I'v the early days.
Don't be silly.If people routinely abuse the DSR then it will be taken away. It was probably bright I to encourage online sales I'v the early days.
It can't be abused, you can return it for whatever reason you want. (The person who delivered it had an odious smell) It's the law and it won't be repealed any time soon.What PSU are you using, just out of interest?
Haswell tends to be this gash...
taken away by who ?
DSR is not set by the retailers
Don't be silly.It can't be abused, you can return it for whatever reason you want. (The person who delivered it had an odious smell) It's ththee law and it won't be repealed any time soon.
