***The Vapers Lounge***
Status
Not open for further replies.
Thanks for that RedMogg
I have been rebuilding my vivi novas for some time now so hopefully manage a proper rebuildable :-)
Forgot to ask.. I would rather not have to use a needle to fill the tank ala Vivi nova. Does the AGA need to be filled by needle or just standard bottle?
cheers!
Needle's easier, especially if you've got a particularly delicate/sensitive coil setup - but if you tap out the negative silica post, it gives you a second hole to release the pressure build up, then you can still fill with a bottle, even with a dual wick/filled diameter wick holes...
Anyone heard of or used XC-116 ceramic wick? Seems that in the US people are raving about how good it is for RBAs, even for rebuilding protanks. It's not cheap at $7/ft but apparently it lasts a very long time.
Ceramic wick had a bit of a phase in vaping a few years ago and was dropped for being rubbish. They might have a different type now I ain't heard of that is better.
I used to feel so bleeding edge with vaping but am starting to fall behind just using basic stuff to get my nic. Kind of sad but I'm getting what I need without much faff now.
So, gents - what's the best drip with tank money can buy under £50. Something easy to load, reliable, rebuildable, widely available but with container big enough to use during long commute?
My Protank Mini 2 v2 and eGo Spinner arrived today. I can notice a small improvement in vape over my evod so far, but I need to experiment a bit with voltages.
I have some 50/50 liquid coming later this week that I'm looking forward to trying. I've heard that it's best to remove the flavour wick from the protank heads with thicker liquids? I'll try both ways.
I've also got my parents interested in ecigs, but they're not interested in fruit/sweet flavours.
Any recommendations on tobacco flavors? they're looking for a taste as close as possible to normal cigs.
re tobacco flavours house of liquid do some very good ones but they are prone to clogging up wicks / giving pro tanks a very short shelf life. not an issue if you're rebuilding but if you're relying on buying replacement heads then it could work out costly.
cigarellos or Virginia prime are definitely worth a try (houseofliquid.com)
Save another £20 and get a KFL:
Or...
50Euros (inc. p&p)
https://www.vapor-freak.de/Phoenix-Mods/PM-Verdampfer/Arashi-V2-Pyrex
£25 (inc. p&p) but you'll want more wick & wire
http://www.thevapetank.co.uk/product/smoktech_rsst_rebuildable_tank_atomizer
£23.99 (inc. p&p) Gives the option to drip as well as a genny
http://greyhaze.co.uk/collections/rba/products/agi-rebuildable-tank-dripping-atomizer
£20ish, (inc p&p) "Squonking" is my "out there" suggestion...
http://pink-mule.com/MIZERS VÆSKE/rebuildable-atomizere/AURORA-KIT-PLATA-SIVLER
£17 (inc p&p) Dependable, but dull!
http://www.smokshop.com/collections/cartomizers/products/kanger-protank-2
Thanks for the info. Does the rsst need a needle? Its just when I am out and about in my job I would love to be able to unscrew the top of the tank and fill up directly by bottle.
Not a chance, unless the bottle has a syringe at the end of it. You can but them from nearly every vaping shop...
Just bought a caffeine infused e-cig (no nicotine) because I find it hard to sleep or stay awake when I should and as a result drink a-lot of coffee or energy drink which disagrees with me.
So I figured I would drink water and puff one of these instead. It's alright, nothing special, quite cheap and not a proper vaper with a replacable cartridge etc.
Does anything similar exist but in a slightly more 'substantial' form? Like a caffeine cartridge for a regular vaper? (without nicotine I mean, which is the issue)
:mad::mad:Royal mail are a ****ing bunch of ****sticks.
They failed to deliver my Gus yday and left a card so obviously he had the parcel.
Went to pick it up today and no record of it being processed at the depo after failed delivery.
The Manager said she will call the driver to get him to find and bring the parcel in so that I can collect it later today.
But the sheer incompetance.
If the parcel is not found its 100% the drivers fault and I will make HELL fo them.
:mad::mad::mad::mad::mad:
Status
