Thanks for that RedMogg
I have been rebuilding my vivi novas for some time now so hopefully manage a proper rebuildable
Forgot to ask.. I would rather not have to use a needle to fill the tank ala Vivi nova. Does the AGA need to be filled by needle or just standard bottle?
cheers!
Needle's easier, especially if you've got a particularly delicate/sensitive coil setup - but if you tap out the negative silica post, it gives you a second hole to release the pressure build up, then you can still fill with a bottle, even with a dual wick/filled diameter wick holes...
