Windows 8.1 not showing up in store
6 Apr 2009
Liverpool
ive tried all day all the updates are updated but still no update showed instore....anyone got any ideas....i am running windows 8 pro with a volume licence thanks
Windows 8 installations using VLC/KMS won't get in in the store, the store is for retail consumers only. If you want to update 8 > 8.1 then you need to get the 8.1 Pro installation media and update that way.
It clearly says this on the MS Windows website
says i might need to install a clean installation of windows .....sack that ill stick to windows 8.....to much bother
You don't need to, the update can be run from the 8.1 Pro media itself. The hard part is getting a hold of the ISO from MVLS site as it's being hammered and downloads are stopping
