Cool, can you Whitelist me pls
User is cuffylad
white listed this is the last one i will do from here
use the LT forum for the requests
User is cuffylad
Is this something that can be added ? I googled the question but didn't understand what anyone was saying on the topic. I don't know where to start without ARS as I don't want to go down the uber complicated Gregtech pathFound a hilly bit \o/ which is home while I explore, I like those really tall trees
Happy that getting back on was pretty painless, no breaking the Enigma code required or editing files in Latin this time, just point at the new FTB thing
Quickly realised there is no ARS Magica installedIs this something that can be added ? I googled the question but didn't understand what anyone was saying on the topic. I don't know where to start without ARS as I don't want to go down the uber complicated Gregtech path
Yrth, I'm currently whitelisted on the vanilla server but do I need to be listed on the FTB one as well? I'd like to give this a try tonight... Ta.
Thaumcraft ? I think you get Flight after you've researched everything possible. Actually I was hoping to get straight back into what I was busy doing when the map got wiped, so need ARS really...there are other methods to get the things you want.
Server performance is fine until people build acres of gregtech stuff with multiple world anchors, then it all goes downhill rapidly. My simple house was peachyHave a look at the list of mod some you will like a lot some not so much but over all better balance and better server performance
I think the only related mod is Thaumcraft, but research was epically boring and I got as far as golems before giving up due to hair loss. Golems when you think about it are just the same as clever pipes.
I guess I'll twiddle my thumbs until Ars Magica is fixed, hopefully it won't be too long ???
As I'm stuck with just exploring in the meantime, could you turn off that odd zapping border feature please ?
I've never yet seen any warning message before being zapped and last time (being in a boat) I couldn't get away fast enough before it killed me.
Then I apparently respawn in a bed but suffocate in the ceiling above it ???
By default it only saves the last death location (which is now my bed) so I've no idea where on the map I've actually died, and since I was in a boat I've got very little chance of recovering my stuff from the seabed anyway.
The previous method of flipping you 180 degrees was sufficient I think![]()
Thaumcraft research up to flight is pretty expensive though even if it's relatively cheap to create once you have the research completed.Have you seen the gregtech insanity of what's involved though ? https://www.sugarsync.com/pf/D0270249_62548212_42524 and that doesn't list the million other things required to get certain bits like IridiumYou can make several types of suit that offer flight, I know I've made the gravchestplate now on my mates server and it's pretty damn awesome![]()
Have you seen the gregtech insanity of what's involved though ? https://www.sugarsync.com/pf/D0270249_62548212_42524 and that doesn't list the million other things required to get certain bits like Iridium![]()
I'm guessing the new mod server is using this list of FTB mods:
http://feed-the-beast.com/mod-pack/unleashed
Now that looks like a lot of mods that do a lot of things...
Before I go searching for info on all of them (as the FTB site doesn't have any that I can find), does anyone have a list of stuff that one can do with all these mods?! Just the main things would be nice...
Oh I dumb, you are right it's not in, which means the macerator recipe is something else again I think. The jetpack was OK but really only for hovering around your house, the ARS Flight spell let you travel the worldAre you sure gregtech is on the pack we're using? I haven't done much but I haven't seen any evidence it is yet. A good old ic2 jet pack is pretty easy to put together if you want to fly around the place.
I used that a thousand times a day. Actually why are we on this Unleashed pack anyway ?
are there any restrictions on making a wither too?Is there an easy way to get a nether star? (other than killing the nether thing) Trying to make a portal gun but the nether is fairly hostileare there any restrictions on making a wither too?
Just seen that there is a new recipe for it in NEI, hopefully that'll work.
