If running on air, I would avoid buying these 290x cards if planning on keeping for 3 years. I would wait for the die shrink next year.
This card is a top performance card but its also very hot as it is at the technology limits of what is possible.
The die shrink will give you all this performance with significantly less heat.
I personally haven't really spent time on the TTL/OC3D...but ironically, with followings like that it doesn't exactly paint a good picture for reviewer themselves...
And as for heat and noise - if it bothers you that much wait for non-reference. I can't believe, given the price/performance, some of you are letting it put you off the card!
It is, but the choice is either to wait a month and a bit, or pay another £300 for around the same performance.
SLI GTX670 is good performance no doubt, however its low memory bandwidth (because of its narrow 256-bit bus size) would mean you would get much greater performance hit when using settings such as SuperSampling, and playing memory intense titles such as Metro, or...any games that uses high res texture, and this apply for 1920 res, not just higher res.Great performance but I will be asking for a refund on my pre order. I wanted something quieter, cooler with less power for not much performance loss over my sli 670's. This doesn't really fulfill those criteria! Also I'm still at 1080p and it seems it only is 780 performance at that resolution.
Can't deny the performance at high resolution, looks like a great card if you don't mind noise and heat.
lol looking at these graphics...the pricing for the two top Nvidia cards are like out in space or something...You have to say AMD have got it all covered on Price vs Performance from top to bottom. Every single card is not only faster, but cheaper.
If I was in your shoes, I would probably do the same in keeping the SLI GTX670, but I'd make do with not using settings like SuperSampling etc. If you not crazy about games like Metro, the SLI GTX670 would still be fine in the short term, and should last you till next gen 20nm upgrade.
