cool - the aforementioned pre-build spec has it at a 4ghz o/c, i might go down the aftermarket cooler route to make sure he has a good chance of hitting that.
Asus Z87I-Pro have so much better layout than Gigabyte, I wouldn't go for any other motherboard for mini-itx rig. And have 6 sata 6gb instead of 4 like Gigabyte. Easier to route power cables and hide them behind RAM sockets.
And have very nice color, looks very nice with Avexir yellow/orange ram
CPU comes clean as my buddy Idleman has already said
I'd still go with my spec but of course I'm biased lol The MSI 280X is great value, I'd probably toy with putting Corsair SP120 QE fans on the CLC at some point and use the red rings to tie that colour in more.
As you called him cheep (like the budgie). There is a trial for Windows 8 he can use for free saving £70 for now, if he hates 8 he can buy 7 no harm done. Also how often will he use an optical drive? If it's just for the OS install you can use a pendrive or lend him the use of your ODD for a bit. If you leave the ODD out as I hinted before, you can get the H100 which has the larger radiator for better cooling at a few quid more.
All the best with it boys, we'd love to see some pics of it complete
I think he'd look at me a bit strange if i didn't put an optical drive in there.
Also he mentioned that he'll be playing games mainly along the lines of football manager and total war so i'm wondering if the Gfx card is really required and whether the money would be better spent on 16gig of ram.
Could drop to a Sapphire Radeon R9 280X Dual-X and use the £50 on the ram, though im not sure there'd be any benefit to the extra memory, its not like hes going to be doing a lot of video editing or the likes.
If i could re-jig it would it be worth going to an i7 3.5ghz (would need to find £70 for that obviously) - i've heard it doesn't offer a lot in terms of gaming performance (over the i5).
No doubt by the time he makes his mind up all of the prices will have changed and i'll have to start from scratch
If he plans to use this rig for some high res video rendering, then 16gb ram is ok, but if its just for gaming there is no point in using more than 8.
I had 16gb in gaming pc and never used more than half. To be honest I didn't even use 8 gb.
Why not consider another disk instead. Hybride ssd's, so called SSHD's are xheap right now and come in very nice capacity. I have system on SSD, then games and programs on SSHD. I had normal HDD for those before and it worked much slower.
So better use the money on SSHD.
