I can confirm that uninstalling GPU-Z (or just not running it) has resolved the 100% GPU load issue - phew =D
Anyone actually played any games on it yet lol? It's destroying everything I'm throwing at it, but I guess it would do at 1080p![]()
Ah great to hear. Spread the word my man. Gpu-z needs an update. It doesn't even report the right values for the 290X.
LtMatt ye got up at 5am and playing around with this card since then.
Those memory jumping clocks are so anoying that i cant see using this card without those profiles i made in afterburner.
If i only use overdrive and change memory clocks card will crash from this memory jumping after few minutes of reading forums.
So 2 of us have this problem both with sapphire card. Coincidence not sure.
un installing GPU Z then back soon
Zed read this post above. The guy did what i said and he also uninstalled gpu-z and the issue is gone. Worth a shot mate. Also could be a problem with the Sapphire bios. Can always try flashing the asus one. You know where my bios flash guide is if you need it.
Running 1075/1550 with fan set to auto quiet as a mouse with target set to 90c.
Good old Frosty knows what hes doing.
