Gibbo when can I pre order 2 290s?
290X now.
290 is in stock but under NDA until 5am 31st.
^^ I'm talking stock cooling v stock cooling - once you start putting volt mods and aftermarket cooling into the question you've got people hitting what ~40% overclocks over the reference boost clock on the GTX780? - 1200MHz _so far_ seems to the top end of whats attainable of the 290X on stock not the average though that might change as more get into people's hands.
If I buy 2 that date will I get them for 1st?
The first Multi gpu review and it is a comfortable and flawless victory for the 290x crossfire setup. Guru3d went easy by disabling TressFX on Tomb Raider and using DDOF on Bioshock.
1440P
4K
Full Article
http://www.guru3d.com/articles_pages/radeon_r9_290x_crossfire_vs_sli_review_benchmarks,1.html
Just ran a few benches to compare a couple of stock Titans to what Guru3d got for 290X CF
My system
3930k @4.6
Two Titans @stock
16gb Ram @1600mhz 9-11-11-25-1T 96 (Guru3d were a bit vague on how their memory was setup so I ran mine very slow to be fair)
3dmark11 P Score
My Titan = 14004 http://www.3dmark.com/3dm11/7373360
Their 290X = 13685
My SLI Titans = 21838 http://www.3dmark.com/3dm11/7373391
Their CF 290X = 19343
3dmark11 X Score
My Titan = 5110 http://www.3dmark.com/3dm11/7373478
Their 290X = 4693
My SLI Titans = 9547 http://www.3dmark.com/3dm11/7373447
Their CF 290X = 7839
3dmark Firestrike
My Titan = 9559 http://www.3dmark.com/fs/1044020
Their 290X = 9808
My SLI Titans = 15314 http://www.3dmark.com/fs/1044041
Their CF 290X = 16030
Tomb Raider
My Titan = 85.7
Their 290X = 87![]()
My SLI Titans = 165.1
Their CF 290X = 145![]()
I will run these tests again tomorrow when I get my 290Xs running in two way CF
My system
3930k @4.6
Two Titans @stock
3dmark11 P Score
Their 290X = 13685
My 290X Uber = 14439 http://www.3dmark.com/3dm11/7376495
My 290X CF Uber = 22492 http://www.3dmark.com/3dm11/7376751
3dmark11 X Score
Their 290X = 4693
My 290X Uber = 4647 http://www.3dmark.com/3dm11/7376528
My 290X CF Uber = 8904 http://www.3dmark.com/3dm11/7376787
3dmark Firestrike
Their 290X = 9808
My 290X Uber = 9787 http://www.3dmark.com/fs/1046586
My CF 290X Uber = 16535 http://www.3dmark.com/fs/1046752
Tomb Raider
My Titan = 85.7
Just updated these results with my own 290Xs.
System used was identical to the one used for my Titans except I was using a 3970X @4.6 instead of a 3930K @4.6 (they perform the same).
Could not do a Tomb Raider run as I could not get my screen to run @1440p with AMD Catalyst Control Centre.
There are some interesting results on my own 290Xs above running them at stock in Uber mode.
a lot of work gone into that.Absolutely fantastic work there Kaapstada lot of work gone into that.
What is your take on these cards?? do you have an open case?
I like them
I am running with an open case for the benches as I forgot to put the side panel on. With the cards fans turned up the cards don't get that hot for benching. I am using a RIVE mobo with a gap between the cards which helps. I think the way to go is waterblocks and hopefully soon I will have mine fitted.
Is the noise as bad as some are saying?
If the fans are at 100% it is like having a vacuum cleaner in the room. For normal use the cards are not too bad. The good news is two in CF don't sound any louder than one.
I think a lot of people who buy these will be using water anyway. I also think with 1.4v or more available in GPU Tweak there is little point in getting a non ref one for watercooling.
