- 9 Apr 2012
What's Crysis 3 MAXED OUT at 1080p like?
Proud of you Kaapi boi. I knew you wouldn't let me down. After all the crap written about the card, tell me how it is. What do you think? Good card, bad card? Put aside the heat/cooler crap. People buying a reference AMD card should know what to expect.
Good card for £400 vs a £800 titan, or not??
I assume AIB cards will make things much better.
Now now Matt. I know you defend AMD to the death and that's cool but that's not really a fair way to look at it. The titan is WAAAYYYYY overpriced and always was but the 290x is still a £450 card and to gloss over its faults because its cheaper isn't right. They are excellent cards performance wise but reviewers are right to give them crap about the heat and cooler as its still an expensive card and they've made no development on that cooler in years. Not having a go at you matt just making the point that whilst they have got a wicked fast product here they have thrown cooling/noise out the window to get there.
at least you get a bsod . mine is just showing a black screen.... something to do with drivers but not figured out what yet
Just after I posted I got another BSOD. I changed my switch on the card to UBER mode and it seems stable, so far...
That is all I have had mine on so far, Uber mode.
What was the max volts you tried?
Most of the time 1.35v and a couple of runs on 1.375v
I will try higher when I get the waterblocks on.
Good to hear
I take it you've tried all 4 cards?
When i buy an AMD reference card i don't complain about heat or noise. It comes as standard. The faults lie with the cooler, not the card. Anyone with just a modicum of intelligence will wait for a AIB card or use a waterblock. I had a 7970 reference card so i know what they're like. That's how i see it. That's how its been with AMD and ive seen buying their cards since the 9200SE. The reason i asked Kaap for his opinion on the card and not the heat/noise is because i alread know what to expect to get with a reference cooler. The 780/titan may run cooler, but it still runs hot and it still makes a lot of noise if you intend to overclock. So really, its not that much different.
If you turn the fans up to 100% it sounds like your mum doing the hovering
