If you don't mind me asking, how much is this costing and what garage is doing the work ? (I live locally to you in Livingston)
My MK5 Golf GTI is quickly approaching 100k , after seeing this thread again I dropped the sump a couple of weeks ago to check the oil pick up luckily all clear, hopefully helped due to me changing the oil every 6.5k since it was new as a lot of long life serviced cars are getting the pick up clogged up.
I won't be surprised if my oil pump needs replaced, my plan is to swap in a new engine in probably an ED30/S3 K04 equipped engine to make it worth while but curious what the going rate is now for the oil pump, local VW dealer advised around 1k for the parts inc VAT and £200-300 fitting.
