Second issue was the LED's / Dimmers i have, they seem to work fine with 2 LED's installed apart from where i have a Master/ Slave (2Way) lighting setup, i assume this is due to the fact that to power up 2 switches a little more current is needed and this pulls about enough to have the LED's flashing very dimly when switched off, so my plan is to install an extra light onto the landing lights into the loft so that when switched on i will have light up there and also resolving my flicker problem.
The other 2 LED's i have is in my living room where i have a bank of 8 and then 2, 2 which will be over my dining table, im still trying to see what i can do about this one i'll probably end up with a RESLOADE which is basically a big resistor which simulates a 10w load on the circuit which should resolve my flicker problem.
You shouldn't have any problems with the dimmer & flickering lights, if it's a trailing edge model.
2 way switching shouldn't be a problem, if you use a TE dimmer one end & other end a ordinary switch.
As for two lights over the dining table wire them independently & use with a seperate dimmer.
One of the best dimmers I've use, is Varilight V-Pro trailing edge dimmer, they have one of the lowest minimum load settings of all, just 10 Watts.
One particular model 'V-Pro eclique dimmers' can be dimmed from multiple locations, using a eclique slave dimmer.
