so once i've unlocked it via VPN do i have to remain connected to the VPN to play single player ? what about if i want to play multiplayer, do i still need to stay connected to the VPN ? surely this will create bad lag unless the VPN is amazingly good ?
[TFU] Thegoon84;25206448 said:
CHECK THE FRONT PAGE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
XXX
Cheers for the query port
Anyway to speed up Origin ? What speeds did you guys get ?
Updated OP.![]()
If I pause the download and close origin do I have run the VNP again when I start origin? or start the whole download again......
[TFU] Thegoon84;25206568 said:You'll know as BF4 will either be grey'd out or not!
can't get this proxy/vpn thing to work at all (both flyvpn and the reddit one linked [error code 2 non stop])
Can I just do it the manual way through the control panel and using an IP/port
http://hidemyass.com/proxy-list/
