- 13 Jan 2004
- South East
Hi all,
I ran the Windows 8 upgrade wizard last night, and it said that if I upgrade I'll need to reinstall all of my compatible apps.
Why is this? I thought all your apps were able to be carried over from Windows 7? I'm on a 64 bit version of Windows 7.
I have it installed to an SSD; some applications are install on the SSD, but most are installed on a second hard drive.
If I go ahead with the update will it wipe all of these applications? Or will they just not work, requiring me to reinstall in order to get them working again?
Thanks
Thanks
