- 6 Aug 2009
- Wales
Physics score in general, it seems awfully low?
I think it's something to do with Gpu tweak pal, seems to mess up my cpu score on both this and firestrike.
That's a ****er then, because you're only getting slightly higher than stock 4770k physics scores.
Different system etc, but i get 11200 for stock+turbo 4770k and over 13k for an overclocked 4770k (4.9Ghz) Does lowering the clock give you more or less, or just not tried?
Stock
Overclocked
That is pretty strange. Was your physics scores broadly similar before you had the 290X? Or is it just since installing?
The only thing it could be is if your ram is somehow running single channel, but even then i wouldn't of thought that would drop off 2k physics score compared to mine. Though ignoring that, you did say all the other benchmarks put you inline with the other 4770ks, just 3D11 being a ****!
All updated and welcome to the thread DonNice score as well.
How are your CF 290X's running Darket? Do they throttle?
Gtx 780 aircooled
core/mem 1172/1662
2500k @ 4.7 watercooled
http://www.3dmark.com/3dm11/7405636
http://www.techpowerup.com/gpuz/3wa3q/
P13600
Graphics Score 17198
Physics Score 8292
Combined Score 8456
Managed to break 18k on my setup.
Score 18084
EVGA Titan, Koolance block, 1385 /1925................cpu 3960X 5485 (SS)
http://www.3dmark.com/3dm11/7412985
Graphics 18570
Physics 17841
Combined 15383
Score 18084
Graphics 18570
Physics 17841
Combined 15383
