Hope someone can help here. Having trouble with my Samsung EVO 250Gb. Firstly I bought another drive (a 120Gb version) at the same time and installed that in my dad's PC without any problem after a fresh install of Windows 7.
I've tried doing a fresh install of my own drive in AHCI mode which fails/stops early on during the installation process. Can't remember the error message I get unfortunately but basically says that it isn't able to install Windows.
Have tried in IDE mode which took several attempts to install. Once installed, it might work for a short time but then when I reboot I'm getting WINDOWS BOOT MANAGER, fail to start errors.
Have tried using the Samsung Magician to clone from my existing Windows installation (on RAID Samsung F3 1TB) as well but getting the same errors. Have left it in RAID mode but it made no difference. It typically states that ntoskrnl.exe is missing but others include:
winload.exe
volsnap.sys
iaStorA.sys
volmgrx.sys
Ntfs.sys
fltmgr.sys
mup.sys
If I keep pressing 'Return' it eventually boots. I've tried doing a repair of windows as it instructs but it just stuck at 'detecting windows installation'.
I've also tried to switch to AHCI mode after installing in IDE using the regedit/MS fix it tool method but I just get boot failure so I don't know what else to do to enable it. Any ideas?
I'd even bought another hard drive (Seagate Barracuda 7200.14 3tb) as I thought it was the RAID setup that was the problem. Wished I'd asked on here first.
Samsung Magician says the drive health is good.
Can someone help me here please? Is the drive faulty? Would be nice to stop swearing profusely at the PC. Thanks!
winload.exe
volsnap.sys
iaStorA.sys
volmgrx.sys
Ntfs.sys
fltmgr.sys
mup.sys
