***The Vapers Lounge***
Status
Not open for further replies.
Postie delivered a couple of Kanger Pro-tank IIs today. Very impressed with the build quality and they vape so much nicer than my Novas or BCC Megas.
Well seeing as ive now got the gist of recoiling and wicking my KFL, my protanks have all but been discarded. Ive kept one protank which seems to work fine, the other 2 always give me problems as they seem to have a much tighter draw compared to the one im keeping.
If anyone wants them then let me know, i reckon £5 for the pair of them will cover the cost of postage. They have only been used a couple of times and ill be putting new heads in them for you.
But the KFL just blows everything out of the water once you get it properly coiled and wicked. Really should get onto micro coiling at some point, suppose once ive finished my tank of rapsberry juice then ill give the micro coil a shot.
Vapemail! :)
One of each of Scoopes flavours that i haven't tried, Peach, Blueberry, Berrylicious and Banana with my two weapons of choice. :)
heres my current collection, listed the poldiac on ukvapers but only got trades offered so looks like im keeping it. rest im ok with because ive ordered some magnets for the nemesis so that should end my frustration with the switch.
Please keep images to below 1280px wide or post in
tags like I've done for you above - Rilot
Yas - I'm very nearly done putting together the first MicroCoil Kits - if you can wait til Weds, I should have them ready to post.
The Kit will contain everything you need to get started with Microcoiling (minus the tools - flat needle nose pliers and blowtorch/decent windproof type lighter.) - I'm sure you've already been in touch via Trust - if not, do so and I can give you all the details ;)
Hey Red, yes i did contact you a few weeks ago and you said you were waiting on some stuff before you sent out the kits. Im still interested in the kit, i do have pliers and a blowtorch as well.
If you can trust me with the details of the kit then we can take it from there.
vamo and kayfun on left and provari on right but is that the new kanger protank on the provari. looks pretty cool
Yep thats right, The Vamo is the new V5 or VE depending on where you look - http://www.vapeescape.co.uk/MODS--Advanced/Ego-VV/VW-VAMO/Vamo-VE-Stainless-Steel.Html
Brushed stainless just like the KFL. :)
Yeah thats the new Protank II, I still use them and the on occasion the original ones when I'm out and about. Still cant beat the KPT for being quick and easy to use if your out or want a quick change of flavour. (imo)
Also have a beauty ring for the ProV if i fancy rocking the KFL on it.
VAPE MAIL!!
Ordered some Scopes juice last night, Raspberry and Apple Tart, I got them today along with a 5ml Banana? Also ordered 30mil more Monkey Jizz and 10ml Zombie Pus...
what sanding gumpy
the mod is simple as can be, just take one of the magnets and sand down the outer diameter until it fits into the end of the battery tube,thats it , then it will work with any battery you want to use.
i centered the other magnet in the end of the button using a piece of thin aluminium and glued it to the alu disc so it was a nice snug fit in the switch as i noticed it was being moved out of ideal position, this was probably a little anal of me .
i also used a small copper washers between the firing pin and the brass switch housing to reduce the throw to about 1mm or so, as i considered the throw to be a little long.
Taken from Fasttech discussions.
Status
