Got a weird issue with my S4 - currently think it might be the celluar baseband crashing, although when the issue occurs occasionally it results in the phone not being able to see a SIM card.
Had the issue with PAC Man rom where it couldn't see a SIM card (and so no mobile signal), so changed to Omega 13.1 (TW based) ROM. Seemed to be OK however it would loose signal altogether unless the phone was unlocked and the screen was active. Any time the screen went inactive signal would disappear. It's now showing the same symptoms I was seeing under PAC Man, sometimes I can use the phone fine for a while (although only while the screen is on). Eventually it seems to "loose" the SIM card and can't see that one's present. Either rebooting the phone or hard resetting it by taking out the battery "fixes" the issue for a while.
Anyone ever seen or heard of anything like this? Just about to try another SIM card to rule that out and try this SIM in another phone, but also wondering if its a baseband/firmware/ROM issue?
. Suspected it may be that, but only got a bit of time today to actually try and fix it!
