- 12 Oct 2010
- Stratford, London
Is there no specific Macro option in the camera app?
Been reading review on the Verge -![]()
CPW price up to £429 now - glad i bagged one at £295 yesterday.
For those of you that want to replace Hangouts, you can get a working 4.4 AOSP MMS.apk from here:
http://rapidshare.com/share/B9A76F0C553E0D4B4579AAD97D5D07FA
Original thread here:
http://forum.xda-developers.com/showthread.php?p=47149044#post47149044
Side load as normal. When opening it for the first time it will prompt you that Hangouts is currently set as default. You can now change that in Settings and disable Hangouts if you want.
Compared to my HTC One the speakers are useless both in quality and design. I've just been playing GTA and as I'm holding the phone, my hand covers the speaker :/
Excellent - thanks!
The hand covering speaker is my biggest gripe so far, however I do find it less of a problem if I switch it 180 degrees, but it still covers it a little bit.
Anandtech are amazing, one of the only decent techy sites out there, I gave up Tom's Hardware and the like many years ago.
I'm a bit disappointed by the Nexus 5 overall I think, obviously I'm just going off of the reviews but I was hoping for something more.
Yes the 16Gb is pretty cheap SIM free but the 32GB is £339 and I could buy the Galaxy S4 for £414 direct from Amazon (no dodgy sellers), this is only 16GB but not an issue as it has the memory card slot and I already have a 32GB card ready to drop in.
Best use of dodgy maths ever to illustrate a point.
If the S4 is £414 for 16gb then the Nexus 5 is £289 thus making the samsung phone nearly 50% more.
You can not compare apples and pears, although your example does.
Notice from your sig that you use strava? You had any issues uploading from the app on the nexus. Mine just won't sync an activity..
won't work, downloaded the GPX from the phone and uploaded manually, guess it needs an update before it works properly with 4.4
