So what you're saying is that you're dense ?
That didn't come out right![]()
Dropping weight due to a bad back isn't a sensible idea, it's better to build up the strength of your back so that it's not an issue. Dropping 10KG~ across your whole body isn't really going to do much to take the strain off your back.
I think the phrase is 'dangerously underweight'. A BMI of 15.8 is just as unhealthy, if not more so as a BMI of 31.1....
Aweome assessment there... dr...???
When my personal GP tells me im "dangerously underweight" ill listen. To people on the internet? Not so much.
Im actually somewhat well "toned"... would be the word![]()
36" waist and you don't think you're fat?
Good luck with that, GPs aren't known for being particularly good, especially when it comes to weight.
My private GP is exceptional. In fact, he used to be concerned about my weight until he ran every test under the sun, sent me for scans, blood tests, fitness tests, even in touch with a specialist nutritionist.
All the tests and scans came back perfect. The fitness tests showed I am in better shape than most "normal" people.
Call it a fast metabolism, luck of the draw or whatever you will, or just a good and very healthy upbringing (I cant stand the taste of foods high in fats/saturated/high in salt, I don't drink and don't smoke), at the end of it all, the only conclusion they could come up with was that, thats the way I am.
I can get myself an extra 10KG in weight very easily by swapping my cardo-based workouts for weight-based ones, however, when I stop, within 12 months ill have lost that muscle weight again, and never drop below 55kg.
Good luck to you and I hope you are right and you are a a toned and healthy person and remain so....although if your GP is saying that you are fine with a BMI of 15.8 then you might want to get a second opinion, just to be sure.
*insert highly skeptical response*
Fats and saturated fats are very good for you, avoiding them is certainly not the mark of a healthy diet.
I'm not really sure what you're trying to say here.
When I refer to fats, saturated fats and salts, I refer to junk food, fast food, readymeals etc. Rather than fish and chips from the chippy, id have a peice of cod from the fishmonger, with a home made parsley sauce and mashed potatoes. Rather than a McDonnalds, id hand make a burger with lean mince.. you get the idea.
Point is, I am very capable of adding and sustaining weight if I so desire. However my natural balance when doing as much cardio as I do seems to be, 55kg.
I have also had the same work done by an NHS doctor, though not as in depth. I see 0 point in going for a 3rd set of tests to find out... the exact same results, again, do you?
