It is a serious question. I have looked and can't see anything that Gibbo has reviewed/tested from the Nvidia side but I can find plenty of reviews for AMD.
What was the last Nvidia card you reviewed Gibbo?
I should have made a bet of some sort out of this780Ti, just not published yet.![]()
The answer would hopefully be GTX780Ti...when it's out![]()
Maybe he just reviews gpu's that let you add voltage to oc the nuts off them.![]()
LOL petey.
Gonna be some interesting results as at least the ocuk review should give us a fair indication of the gtx780ti oc v titan oc v gtx780oc v r9 290x/pro oc.
Ti hammers Titan, I am saying no more!![]()
AMD said:A media outlet has uniquely reported instances of AMD Radeon R9 290X boards purchased in retail that have exhibited an uncharacteristic level of performance variance as compared to press samples issued by AMD. We’re working to secure the board(s) in question for further analysis.
AMD said:Boards purchased by other media outlets have not exhibited similar characteristics that we’re aware of.
AMD said:In the meantime, we’ve identified areas where variability can be minimized and are working on a driver update which will minimize this variance.
Personally I think the whole "boost" situation is totally messed up, I liked it when we had a simple "this card runs at #MHz" then Nvidia started doing "This card is clocked at #MHz but will run faster depending on cooling" and now we have AMD saying "This card will do up to #MHz depending on cooling". They could have at least gone for similar methods so not to confuse the consumer...
