kona Yes Mate it finally arrived on Tuesday after blasting Parcel Farce. Thanks for asking, it's lighter than expected but the white back isn't very grippy.not sure if I'm going to keep it though because the G2 is serving me well and I have a problem as windows explorer doesn't see the Nexus 5 when I plug it in.
So I followed the steps outlined in the thread below:
http://forum.xda-developers.com/show....php?t=2511829
The problem is that when I go into Device manager - Android device isn't even listed so I can't uninstall the drivers to begin with. It's not even listed under the other devices tab. There is a Samsung Device listed and when I go to that tab Android device is listed under there so I follow the procedure to uninstall / reinstall but still get the same problem. I had exactly the same issue with my Nexus 7 2013 and ended up returning it back to Google.
Funny that when I plug in my Nexus 4 windows explorer sees the phone and I'm able to access the internal memory, same with my other android devices but not the Nexus 5.
You would think just because the laptop is able to see the Nexus 4 the same would apply for the Nexus 5, however I can't access the memory on the N5 so I can transfer my files across to it.
Any suggestions as to how I can get my laptop to see my Nexus 5 and play nice?
